Go to Post You are becoming the leaders of tomorrow by leading today. - Chris Fultz [more]
Unread 20-01-2014, 14:24
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
FIRST Choice Solenoids need base ?
A rookie team we are helping has a number of FC "Double Solenoid Valve Kit (fc14-098)". I have not seen them yet. Does anyone know if they require bases to be useful or can you screw in a air source into the bottom of them ? If bases are needed, happen to have a link to them ?
Unread 20-01-2014, 14:29
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: FIRST Choice Solenoids need base ?
These shouldn't require any any additional base parts to function. The 3 ports screw into the module and then you just put in the pneumatic tubing.
Make sure you use an M4 wrench to tighten the fittings -- unlike some nameless students from my team who thought the valves were defective when they pressurized the system and had leaks...
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 20-01-2014, 14:34
de_ de_ is offline
AKA: Dave Edwards
Thanks That's good news.
Looks like your students are made of the same stuff as ours
Unread 20-01-2014, 17:55
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Dave,
Everything you need to wire and add air comes with that fc-098 kit.
A little hint for the quick disconnect fittings is you use a 4 mm hex key INSIDE the fitting to snug it into the value.
Another nice thing to know is the two blue buttons at each end will allow you manually turn on the value without the need for a electrical control. Real handy for testing.
Unread 20-01-2014, 18:23
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
For reference:
http://team358.org/files/pneumatic/Festo24vFittings.jpg
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 20-01-2014, 22:31
de_ de_ is offline
AKA: Dave Edwards
Thanks again. Great picture. We've very familiar with SMC stuff. Never seen the Festo stuff. I am sure we will be up helping our rookie team with their pneumatics any day now
Unread 21-01-2014, 05:38
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Snug away but also use the teflon tape on the threads in the usual manner. Be sure to use the correct mm size. You neither want to raise any burrs nor leave any metal shavings inside the valve. They make a base for multiples of this valve that will make more sense to use if you are going to line up multiple solenoids. I found them once, but we skipped pneumatics last year, so my notes are in another book . . . . . somewhere.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 21-01-2014, 05:58
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
We got some of these valves also (FC14-137), but not the complete kits - they were already sold out. The only thing we're missing are the wired connectors that plug into the solenoids. We have the sub base connectors (FC14-132) but they do not come with the wired plugs.
Anybody know a source for them???
