Go to Post This is definitely the best FRC parody of an FRC parody I have seen. - Jared Russell [more]
Unread 20-01-2014, 14:36
ArchosR4's Avatar
ArchosR4 ArchosR4 is offline
User of the Matrix
FRC #2130 (Alpha+)
ArchosR4 is an unknown quantity at this point
Lumen output of green led light ring in FIRST Choice
With vision targeting requiring a bright source of light does anybody know the lumen output of the light ring available in FIRST Choice? Also how effective is the light ring at longer distances? Thanks
Unread 20-01-2014, 15:03
Re: Lumen output of green led light ring in FIRST Choice
The lumen output is right on the First Choice page: http://firstchoicebyandymark.com/en/fc14-060
The distance will depend heavily on your vision code and camera settings. If you're code can reject false detections, you can open up the thresholds and your light doesn't need to be as bright. Alternately, if you turn down the brightness of the camera, you will need a brighter light, but it will minimize the number of false detections. The best thing to do is start playing with it now.
In 2012, we used only 6 LEDs (significantly less bright then the FC ring light). We could detect the vision targets from the key (12 feet away).
Unread 20-01-2014, 15:05
ArchosR4's Avatar
User of the Matrix
FRC #2130 (Alpha+)
Thanks for the quick reply. Overlooked that information will be of great help. Thanks
