Go to Post There are two types of team members and mentors: Those who want to be FIRST, and those who want to be first. - Tetraman [more]
Unread 20-01-2014, 15:12
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: 2014 Vision Code
Originally Posted by jojoguy10 View Post
Looking at it more...I think processing on the cRIO would be easier. We're only using Vision for Autonomous, then we're planning on disabling vision.
Careful with that. When we tried that in the past, we found that it lagged the cRIO so much that we started getting watchdog errors - the cRIO couldn't communicate fast enough.
As for sending data from the DS back to the robot, you can usually just use NetworkTables to send the data. NI's code and RoboRealm both have easy NetworkTables integration built-in. (Not sure about OpenCV, haven't tried it.)
Unread 20-01-2014, 15:32
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Thank you all for the help! We'll be doing some major testing to find the best route to go with and I'll come back with some questions if needed.
Thanks again!
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 21-01-2014, 21:36
That all depends on the rate and complexity of the processing. You could probably get away with processing 1 image per match this year which shouldn't cause any problems at all running on the cRIO.
Unread 23-01-2014, 09:53
bvisness's Avatar
Depending on your auton routine of choice, I suppose. We're going to try for more complex autonomous routine this year, so we'll need as much flexibility in the vision as we can get.
Unread 23-01-2014, 10:57
The LV example code for finding a game ball is takes two passes. While it would run on the cRIO, the robot and potentially the ball are both moving. I would think it would be hard to accomplish this without a DS or additional processor. The field targets seem pretty easy to do on the cRIO or any of the other approaches. By the way, "easy-vision" is still vision -- it's all relative.
Greg McKaskle
