Go to Post You can never go wrong by gaining height by way of a Segway. - Elgin Clock [more]
Unread 20-01-2014, 16:06
John20 John20 is offline
FRC #3543
John20 is an unknown quantity at this point
viewing sensor data
How do we send sensor data to the driver station so we can see it while driving instead of having to use the wind river console and a printf?
My team is relatively new to complex coding like this and could really use some help expert or otherwise.
Unread 20-01-2014, 16:10
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: viewing sensor data
You could use smart dashboard.
Details on setup and use are here: http://wpilib.screenstepslive.com/s/3120/m/7932
Sending values is as easy as calling the correct 'put' function:
http://wpilib.screenstepslive.com/s/...-robot-program
http://team2168.org
Unread 21-01-2014, 10:28
m1tche11d m1tche11d is offline
m1tche11d
FRC #1997
m1tche11d is an unknown quantity at this point
Alternatively, you can do one of two things.
1) If you look in the given example codes, one of the selections should be labeled "Print to driver station" or something similar. (I don't have windriver with me so I can't be certain) If you open this it should give you example code to print values to the driver station.
2) Use a multimeter and read between the gnd and the sig pins of whatever sensor you happen to be using. This should help you determine if a sensor is working or not, but won't help you if you need to actually put values in the code.
