Go to Post Magic doesn't count as a support, sorry. Neither does simply constraining in CAD... - EricH [more]
Unread 20-01-2014, 11:51
jdaming jdaming is offline
jdaming is on a distinguished road
Low Goal Scoring
For all teams thinking about low goal scoring what steps are you taking to ensure your bot will be able to score in the low goal consistently especially in autonomous?
It seems to me that there may be a problem with a wide base pickup bot if the intake mechanism doesn't extend all the way to the edge of the robot as the goal is up against the edge of the field. Does this seem a legitimate concern?
Unread 20-01-2014, 11:55
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Re: Low Goal Scoring
Our bot is a little wider than it is long and our low goal scorer fits in the side. If we hadn't gone that route, we would have probably used a gyro to turn the bot the few degrees it needed to score in the goal.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 20-01-2014, 17:25
cir3 cir3 is offline
FRC #4265
cir3 is an unknown quantity at this point
Low Goal scoring focused teams can just roll the ball into the low goal to score, but they need to worry that if the other robots on the team are bricks they can only score one point, so they need to be able to throw the ball into the high goal.
Unread 20-01-2014, 17:46
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Although we haven't tested this with a robot, from playing around with the low goal on the official field at the Manchester Kickoff, and from what I have heard from other teams, you absolutely can NOT just plan to roll the ball into the high goal. First of all, the rumors I have heard seem to all agree: it is really difficult to push the ball in front of you without some sort of device to guide the ball. And with the recent team update, a defender can now just knock the ball away from you if you aren't actively controlling it. Then, when you get to the low goal, I have found that the lip is too high to just push the ball over it. So beware of just rolling the ball into the low goal.
Unread 20-01-2014, 19:46
Procolsaurus's Avatar
Procolsaurus Procolsaurus is offline
AKA: Robert Pond
FRC #4118 (Roaring Riptide)
Procolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really nice
Having rolled a ball at a wooden low goal, the ball will not simple roll in. The ball can, however, be pushed in with bumpers.
Unread 20-01-2014, 20:18
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
We did extensive testing and it will NOT just roll in! We have designed our pickup to be able to pickup balls, reverse and roll it to others, and also roll it into the 1pt goal.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 21-01-2014, 07:57
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by Pault View Post
...from what I have heard from other teams, you absolutely can NOT just plan to roll the ball into the high goal. First of all, the rumors I have heard seem to all agree: it is really difficult to push the ball in front of you without some sort of device to guide the ball...
We built the low goal and tested with un-powered chassis. You're correct; the ball will not roll into the low goal (at any speed); it deflects off the lip. You can push it in straight-on but takes some force and bumper height matters.
