Go to Post Its not about Poof balls or green lights or getting up on the ramp at the end, this is about the learning experience and inspiration gained throughout the year. - Winged Wonder [more]
Unread 20-01-2014, 17:31
jnoyeslaser jnoyeslaser is offline
Coach Noyes
FTC #5905 (Camdenton 4-H LASER)
jnoyeslaser is an unknown quantity at this point
[FTC]: Servo to button programming teleop
I am a first year FTC coach trying to learn the world of RobotC programming after years of FLL coaching. My team is stuck on programming their two arms to pick up blocks. The following code is our attempt. The robot will drive using joysticks but we can't make the second controller move the arm nor can we make the buttons work. I have looked through the post both here and on the robotc forum but find nothing to help me function them the way the kids would like. They want the trigger buttons to open and close their "hand" servo, the 1-4 buttons to move the "shoulder or elbow" servo up and down, and the DC motor "lift" to be moved by the joystick on controller 2. Anything you can give us would be great help as we compete in 2 weeks. Thank you so much
#pragma config(Hubs, S1, HTMotor, HTMotor, HTServo, none)
#pragma config(Sensor, S1, , sensorI2CMuxController)
#pragma config(Motor, mtr_S1_C1_1, motorRight, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C1_2, motorLeft, tmotorTetrix, openLoop, reversed)
#pragma config(Motor, mtr_S1_C2_1, motorLift, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C2_2, motorL, tmotorTetrix, openLoop)
#pragma config(Servo, srvo_S1_C3_1, servoTleft, tServoStandard)
#pragma config(Servo, srvo_S1_C3_2, servoAleft, tServoStandard)
#pragma config(Servo, srvo_S1_C3_3, servoTright, tServoStandard)
#pragma config(Servo, srvo_S1_C3_4, servoAright, tServoStandard)
#pragma config(Servo, srvo_S1_C3_5, servo5, tServoNone)
#pragma config(Servo, srvo_S1_C3_6, servo6, tServoNone)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
#include "JoystickDriver.c"
void initializeRobot()
// Place code here to sinitialize servos to starting positions.
// Sensors are automatically configured and setup by ROBOTC. They may need a brief time to stabilize.
servo [servoAleft] = 250;
servo [servoAright] = 150;
servo [servoTleft] = 100;
servo [servoTright] = 100;
return;
int RarmPos = 0;
task main()
//servoAleft needs to be set//
initializeRobot();
waitForStart(); // wait for start of tele-op phase
while(1 == 1)
getJoystickSettings(joystick);
//deadzone on drive motor on joy1
if(joystick.joy1_y2<5 && joystick.joy1_y2>-5)
motor[motorLeft] = 0;
else
motor[motorLeft]= joystick.joy1_y2/2;
if(joystick.joy1_y1<5 && joystick.joy1_y1>-5)
motor[motorRight] = 0;
else
motor[motorRight] = joystick.joy1_y1/1.5;
//right arm tele two tests have been tried
// if(joy2Btn(5))
//servo[servoAright] = 200; //Open
//if(joy2Btn(7))
//servo[servoAright] = 75; //Closed
if (joy2Btn(6))
RarmPos += 5;
if (RarmPos > 255)
RarmPos = 255;
else if (joy2Btn(8))
RarmPos -= 5;
if (RarmPos < 0)
RarmPos = 0;
servo[servoAright] = RarmPos;
//Lift Motor joystick 2 Y1 (left joystick) This one doesn't seem to function properly
if(joystick.joy2_y1<5 && joystick.joy2_y1>-5)
motor[motorLift] = 0;
else
motor[motorLift]= joystick.joy2_y1/2;
//left arm tele
if (joy1Btn(5))
servo[servoAleft] = 200; //Open
if (joy1Btn(7))
servo[servoAleft] = 75; //Closed
//Top Servo Motors to work the shoulder of the arm using the buttons on the right
if (joy2Btn(1))
servo[servoTleft] = 20; //Closed
if (joy2Btn(3))
servo[servoTleft] = 125; //Open
if (joy2Btn(2))
servo[servoTright] = 20; //Closed
if (joy2Btn(4))
servo[servoTright] = 125; //Open
Unread 20-01-2014, 19:20
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Re: [FTC]: Servo to button programming teleop
I don't know if this is your problem but a really easy mistake to make is to plug the servos in upside down, either at the controller or at any extension wires. There is a "YRB" marking on the Tetrix controller which stands for Yellow Red Black and indicates the proper orientation of the wires.
let tau = 2pi
Unread 21-01-2014, 01:09
Just_In_Time Just_In_Time is offline
Just_In_Time is an unknown quantity at this point
I'm not entirely sure if this is the issue but you might want to try putting an "==1" after you assign a button number.
Each button assignment should look something like this:
if((joy1Btn(1) ==1));
//servo code here
Hope this helps.
JIT
Unread 22-01-2014, 09:15
F Elliott F Elliott is offline
FTC #8114
F Elliott is an unknown quantity at this point
The only issue I see with your code is I suspect joy1Btn(5) and joy1Btn(7) should be using joy2Btn(5) and joy2Btn(7). The rest looks fine.
Be sure you have the Joystick-Competition debugger window open and that the dual joysticks are turned on. Fiddle around with the settings in that window. I can't recall off the top of my head what combination works. When it's working you will see the button and joysticks in that window light up with white squares on either joystick. You can try this without running your program. I'll try to get you a screen shot tonight.
Also be aware that on the debugger window the buttons will be shown as 0-7 when pressed but the arguments to joy1Btn and joy2Btn take on corresponding values 1 to 8.
Unread 26-01-2014, 03:33
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Assuming the robot is wired correctly, I can't find anything major that's wrong. However, I have optimized your code a little and made it more readable.
#define DEADBAND(n, b)      ((abs(n) > (b))? (n): 0)
    return;
int RarmPos = 0;
task main()
    initializeRobot();
    while (true)
        // mikets: why different divisors? Are you compensating the robot not running straight?
        motor[motorLeft] = DEADBAND(joystick.joy1_y2, 5)/2;
        motor[motorRight] = DEADBAND(joystick.joy1_y1, 5)/1.5;
        // Joystick 2 controls the lift.
        motor[motorLift] = DEADBAND(joystick.joy2_y1, 5)/2;
        // Use joystick buttons 6 and 8 to raise and lower right arm.
        if (joy2Btn(6))
            RarmPos += 5;
            if (RarmPos > 255)
                RarmPos = 255;
            RarmPos -= 5;
            if (RarmPos < 0)
                RarmPos = 0;
        // Use joystick buttons 5 and 7 to open and close hand.
        if (joy2Btn(5))
        else if (joy2Btn(7))
        if (joy2Btn(1))
        else if (joy2Btn(3))
        if (joy2Btn(2))
        else if (joy2Btn(4))
        wait1Msec(50);
