Go to Post First is more than a competition it is a family. - amos229 [more]
Unread 20-01-2014, 17:03
Christian2443's Avatar
Christian2443 Christian2443 is offline
FRC #2443
Christian2443 is an unknown quantity at this point
2mm key way
My team was wondering how deep to cut a 2mm key way in a 8mm shaft?
Unread 20-01-2014, 17:39
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: 2mm key way
Your depth of cut for a key way is always 1/2 the size of the key you are using.
So if you are using a 2mm square key then your depth of cut into the shaft(8mm) should be 1mm.
