Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-01-2014, 17:00
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Use Mecanum Wheels with AM14U in Wide Configuration
I see that the 2014 kit chassis (AM14U) can support 6" mecanum wheels in its long configuration. However, is there a way to support the mecanum wheels on the wide frame? Our team wants to use the wide frame and mecanum wheels so, I'm just looking for a way to make it work.
Unread 20-01-2014, 20:56
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Re: Use Mecanum Wheels with AM14U in Wide Configuration
I don't see why you couldn't set it up the same way as long, just configure it is wide orientation. Just like any type of wheel.
Unread 20-01-2014, 21:05
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
One caution is you'll have a fairly short wheelbase in that configuration. doable, but not very stable...
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 20-01-2014, 21:09
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I don't think the inside plates are set up for 4 gearboxes in the wide configuration, so you'll have to do some (very precise) fabrication yourself.
Unread 20-01-2014, 21:16
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
If you want to use the given holes for mounting the TB nano with 6" mechanum wheels, you cannot follow the wide configuration cut as the wheel and part of the gearbox will be outside the of the frame perimeter (the sheet metal).
On the attached image, I point out the location of the axle locations.
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
