How to make a winch release freely?
We're a rookie team and are planning to use a winch for the purpose of pulling back our launching arm. We've little experience with all this, so we're having some issues trying to figure out how to make it so that when we finally want to fire, the winch can turn freely without being hindered by the motor that pulled the arm back. We plan on using a high torque motor that turns slowly, though I don't recall the name. It came with our kit.
I've read some posts about getting a gearbox to shift to neutral, among other such ideas, but have no idea if any of them would really work. Could anyone help me? If so, thank you so much! ![]() |
Re: How to make a winch release freely?
I'm no mechie, so I can't give you my opinion on what would work best, but I did see a video from robot in 3 days which went over how they operated the winch on the robot they designed.
http://www.youtube.com/watch?v=xx3I2...re=c4-overview That's one way of doing it at least. |
But to answer your question, yes the method will work if done right. Also, take into account the tension on that dog gear to release from the winching mode after you have pulled back your arm, reason behind Ri3d 1.0 using a longer arm (lever) to actuate it into neutral. https://www.youtube.com/watch?v=xx3I2_CYeGs Hope this helps! ![]() |
http://www.andymark.com/product-p/am-0001.htm ? |
-Keegan H |
#7
For team 4265's winching mechanism we handled the backdriving issue basically the same way one of the ri3d teams did. We had a two-speed transmission, and on one of them it was simply neutral and the other was the drive, and on the drive we stuck a ratcheting wrench in there.
