Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 21-01-2014, 14:02
SBrosious's Avatar
SBrosious SBrosious is offline
AngelicArtist
AKA: Sebastian Brosious
FRC #4085 (Techinical Difficulties)
SBrosious is an unknown quantity at this point
RoboRealm Autonomous help
We are a new-ish Team we are useing Java For our FRC compeititon, We intened on Vision tracking for our 2014 Competiton but we are stumped on how to run variables from Roborealm to the robot and controling it during an autonomous period. We Dont know where to locate/download API or how to use network tables so please help me please be indepth thank you
Unread 21-01-2014, 21:24
billylo's Avatar
billylo billylo is offline
FRC #0610 (Coyotes)
billylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant futurebillylo has a brilliant future
Re: RoboRealm Autonomous help
Check out this tutorial for last year's game. It should give you a jumpstart on vision tracking, camera interface and communication with cRIO.
http://www.roborealm.com/FRC2013/index.php
Unread 22-01-2014, 09:57
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Hello, to send data to the Smart Dashboard, I did the following.
First, I opened up the "Set_Variable" module, and I Set a variable (in my case COG_AREA) and the value to "[Now]". I also clicked the "Set Once" checkbox.
Next, I opened up the "Network Tables" and I put in the IP address of my cRio in the "Hostname" area. Then, I selected the variable I wanted to send.
Then, when I loaded up the robot and opened up the smart dashboard, the variable that I sent appeared on the smart dashboard.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
