Go to Post I'm a drive team coach, they don't eat lunch during competition. - Rick [more]
Unread 20-01-2014, 11:07
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Re: Vision target location
There should be enough at least for the horizontal strip.
The horizontal one "begins 5 ft. 8 in. above the FIELD carpet, is centered over the LOW GOAL, and consists of a panel with one (1) 4 in. wide, 1 ft. 11 ½ in. long strip of retro-reflective material (3M 8830 Silver Marking Film) adhered
horizontally"
This tells you that it is centered above the 2 ft. 8 1/2 in low goal, which is placed in the very corner of the field (its outside edge is in line with the outside edge of the alliance station). Centering a 1 ft 11 1/2 in piece of tape over that low goal would then require you to be .375 ft from the wall (subtract the width of the tape from the width of the goal then divide by two). This translates to 4.5 in from the edge of the alliance station where the high goals are mounted and 5 ft 8 in above the ground, as stated in the manual.
As to the vertically oriented static vision target:
"The static VISION TARGET is mounted such that half is behind the polycarbonate sheet above the LOW GOAL and half is behind the acrylic panel of the PLAYER STATION. It uses vertical reflectors which are located above the inside edge of the LOW GOAL. The vertical reflector consists of a 4 in. wide, 2 ft. 8 in. tall stripe of retro-reflective material bordered by 2 in. wide black gaffers tape on the left and right sides. The vertical reflectors begin 3 ft. 1 ½ in. above the FIELD carpet."
The way I interpret this while looking at the picture is that the center of that reflective tape should be at the inside edge of the low goal. To double check it though you could see what the measurement is from the edge of the alliance station to the start of the acrylic since it states that it is mounted such that half of it is on the polycarb above the low goal and half of it is on the acrylic in front of the drivers.
It's not done until it's overdone!
Unread 20-01-2014, 13:02
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
So, you have the height above the carpet.
FIELD carpet.
You have it's dimensions.
You have it's location relative to another field element.
and the low goal, per the drawings is 36.75 inch wide.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-01-2014, 16:01
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Originally Posted by Bruceb View Post
...You have it's location relative to another field element.
half is behind the acrylic panel of the PLAYER STATION...
That's great and all... but there's nothing available to teams which defines the size of the poly sheet or acrylic panel, or their position relative to anything else on the field.
Try to come up with an actual numeric value. If you find an answer, please share. The closest thing to actually define this information is the field tour video linked previously, but it's not clear exactly what they mean by what they say. (as I mentioned in my previous post)
...and the low goal, per the drawings is 36.75 inch wide.
For the record, the low goal is 36" wide. It's 36.75" tall. See page 4 of the low goal drawing. Unfortunately the cube faces aren't labeled.
This dimension isn't available in any materials provided to teams by FIRST. If you have come a cross it, please share.
http://team2168.org
Last edited by otherguy : 20-01-2014 at 21:28. Reason: added note about goal width/height
Unread 20-01-2014, 16:28
Ex-Driver
AKA: Tyler
Figure 2-9 shows it being the same width as the low goal, and the polycarbonate is specifically referred to as being above the low goal. This would lead me to believe that it is the same width as the low goal, or 2 ft 8 1/2 in + the width of the material that makes up the low goal. I could be wrong on my interpretation, but I believe this to be correct.
Unread 20-01-2014, 21:21
otherguy's Avatar
sparkE
AKA: James
There are no dimensions on Figure 2-9, nor are the acrylic/polycarb sheets identified. Its just a picture of the wall. There's no guarantee it's dimensionally accurate. You had to make the assumption that the poly sheet is the same width as the low goal, but there's nothing in the picture or the text that states that as fact.
I have also come up with a number, which I believe to be correct, based on how I've interpreted the information provided by FIRST (I followed a different path than you've outlined). It's not a matter of just getting an answer though, I want the right answer. Which is why the questions were posted to the Q&A.
http://team2168.org
Unread 20-01-2014, 22:24
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
The video shows a gap between the right edge of the left-lower goal, and the center line of the reflective strip. There is no indication anywhere as to what that distance is.
Unread 21-01-2014, 16:48
otherguy's Avatar
sparkE
AKA: James
Got an answer, see team update 2014-01-21.
Specifically page 4 of FE-00037_RevA.pdf
http://team2168.org
Unread 21-01-2014, 17:52
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
I took a screen shot of the PDF for everyones ease. See the posted image for the final locations of the vision target.
Now that we know where the targets are, back to our Snow Day!
hope this helps,
Kevin
Name:	vision target.png
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 22-01-2014, 12:12
goofy173's Avatar
Electronics Mentor
Thanks for that! I printed it and will give it to our goal builder mentor tonight.
