Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-01-2014, 17:24
thursam's Avatar
thursam thursam is offline
AKA: Sam
FRC #3336 (Zimanators)
thursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nice
Omni Wheel Configuration
I did a quick search, and I couldn't find exactly what I need...
What all would you need to use omni wheels on a robot? Like, a list of everything we would need and how much we would need.
We've never used omni wheels before, so we don't exactly know where to go...
"If you want your children to be intelligent, read them fairy tales." - Albert Einstein
Unread 21-01-2014, 17:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Omni Wheel Configuration
Nobody can answer this question for you. There are too many things we don't know about your robot.
Instead, please tell us what you're trying to accomplish, what you've learned after the research you've done and what questions remain. We can't help you unless you demonstrate that you've done some work and you give us some information to work with.
-Madison
--Madison--
...down at the Ozdust!
Unread 21-01-2014, 17:32
thursam's Avatar
AKA: Sam
There are two videos that explain one of the designs we've been working on.
The Main System
The Intake System
And we don't really have any questions, because we're not entirely sure where to go from our current position. We've done some research, but it's pretty basic. If you'd like to read what we've gathered, I'd be more than happy to post it, but it's really just common knowledge.
Unread 21-01-2014, 17:36
Madison's Avatar
FRC #0488 (Xbot)
The Main System
The Intake System
Sure -- but specifically, what do you need the omniwheels for? Presumably, you'd like to use them in your drive?
Are you using the kitbot? Are you designing your own chassis and drive train?
What kind of axles are you using? Are they dead axles (the wheel spins around a stationary axle) or live axles (the axle and wheel spin together)?
What diameter wheels would you like to use?
What are you expecting to gain from using omniwheels? It is very unusual for teams to use ONLY omniwheels in their drive.
--Madison--
Unread 21-01-2014, 17:39
thursam's Avatar
AKA: Sam
Designing our own chassis.
Live axles.
8" diameter.
Lateral maneuverability and a new experience (for learning and advancement with our engineering concepts.)
We are only using omni wheels. Why is it unusual?
Unread 21-01-2014, 17:47
Madison's Avatar
FRC #0488 (Xbot)
Live axles.
8" diameter.
It should be pretty straightforward to use omniwheels in that arrangement. Both VexPro and AndyMark sell 8" diameter omniwheels. Both of them also offer a variety of hubs that bolt onto the wheels and will give you a hex or keyed bore. You need one hub per wheel.
Driving omniwheels on a live axle is no different than driving traction wheels.
--Madison--
Unread 21-01-2014, 17:49
thursam's Avatar
AKA: Sam
Is that everything, or is there anything else that we would need? We found a diagram for a basic drive system, but we don't need some of it.
Unread 21-01-2014, 17:57
Madison's Avatar
FRC #0488 (Xbot)
Okay, generally --
You need a gearbox with appropriate gearing for 8" wheels. You probably want something in the 12:1 range.
You'll probably need form of power transmission between the gearbox output and your wheels. This is usually chain and sprockets or belt and pulleys. It could also be gears. The power transmission component that turns your wheel's axle will have to be bored appropriately.
In FRC, a live axle is either a hex shaft or a keyed round shaft in nearly all cases. If you're using a hex shaft, you just need a hex bore in your sprocket or pulley and a hex hub attached to your wheel. If you're using a keyed shaft, you'll need a keyed bore on the sprocket and a keyed hub for the wheel. You'll also need a machine key -- a square piece of steel that sits between the shaft and the hub and transmits the torque between the two of them.
You'll probably need shaft collars or some form of retaining rings to stop the wheel and sprocket/pulley/gear from sliding around on the shaft axially. You want to use spacers for this as well.
Folks don't usually use a drive made entirely from omniwheels because it offers almost no resistance to be pushed sideways by a defender. If your strategy relies upon constant mobility around the field, being susceptible to defense may not be a big tradeoff. If any function of your robot requires you to stop in place (to aim, to score, to collect, to catch), an omniwheel drive may be a large liability.
The upside, of course, is that you can swap in a pair of traction wheels for a pair of omniwheels pretty easily and that'll give you some additional resistance to being pushed, spun in place, etc.
--Madison--
On the off chance you don't already know this, if you want to strafe with those omni wheels, you'll need to mount them at 45 degrees.
Unread 21-01-2014, 18:21
thursam's Avatar
AKA: Sam
Thank you both, very much. You have definitely helped a lot.
Unread 21-01-2014, 21:26
yash101 yash101 is offline
AKA: null
OmniWhels are a great piece of hardware. They have so many uses, that it would be useless to name all the possible configurations!
If you want to use it as a holonomic drive, just put a wheel on every of the four sides on the bot. If you want to use OmniWheels to pivot easier and more efficiently, just do a tankdrive, with omni wheels as the far-edge wheels. If you want to be able to easily drift, just make a tankdrive, with nothing but omniwheels!
Unread 21-01-2014, 21:42
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Or at 120 degree intervals!
http://www.ludep.com/working-out-the...he-kiwi-drive/
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 22-01-2014, 03:09
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by kevin.li.rit View Post
You're both wrong. Just make them not all point the same way.
Unread 22-01-2014, 08:27
Nate Laverdure's Avatar
FRC #2363
Note that this description isn't sufficient for describing a holonomic drivetrain based on omni wheels. For example, the attached design is not holonomic (source image).
Unread 22-01-2014, 08:57
It's neither sufficient nor necessary.
