Go to Post Teams that TRY to win and TRY to do their best end up having students that learn more, learn the value of hard work, and are inspired by the process. - Chris Hibner [more]
Unread 21-01-2014, 18:09
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
Re: We Need Serious Robot Help!
I suspect that since you opened two instances of the drive system, they were competing with each other.
I'm enclosing a VI that shows how we opened our Joystick and the Archade Drive System using 4 motors. The code only identifies a 2 motor drive system, the "Y" cable from PWM1 goes to both motor controllers on the left side and the "Y" cable from PWM2 goes to both motor controllers on the right side. All motor control's MUST be of the same type; ie: Talon, Victor, Jaguar.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 21-01-2014, 18:37
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
This is almost certainly the problem.
You only need to have one drive system, the default arcade drive code works fine for your application and did not need to be changed.
I've attached a photo if you don't want to download Chris's code.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 21-01-2014, 21:59
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
The code is the a problem. You are commanding the same motor to go forward and reverse at once, making it not move.
This is actually not a direct result of using two drive systems (they cannot fight each other, drive one only uses PWM 1 and drive two PWM 2). The problem is because you have configured the left and right motors on each drive to feed to the same PWM, and then inverted one of them.
So your code works like this (when you go forward).
-->Get joystick value (1)
-->Set leftmotor to inverted joystick value (-1)
-->Set rightmotor to noninverted joystick value (1)
-->Left motor is PWM 1, set PWM 1 to value of -1
-->Right motor is PWM 1, set PWM 1 to value of 1
Nothing ever happens because you make the motors go full forward and full backward as fast as the code can execute.
Use Chris's code, but modify it for 4 talons (or use y-cables)
Last edited by John : 21-01-2014 at 22:07. Reason: I should not have presumed that this is the only problem.
