Go to Post It is easier than you'd think to get yourself crossed off a draft list. I advise my teams, "Be the team you'd want to partner with." - Joe Johnson [more]
Unread 21-01-2014, 16:45
aewelch aewelch is offline
FRC #4505
aewelch is an unknown quantity at this point
Question Control system Zip Tied
we have a plastic, milk crate like layer that the electronics sit on. We have the PDB, CRio, and motor controllers zipped to the plastic. we also have the wires zip tied to create a nice clean path. is there any issue with zip ties on the control system it holds very nicely. i couldn't find any rules on it.
Thanks!
Unread 21-01-2014, 16:49
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Control system Zip Tied
There are no rules against it. Personally, I would be a little concerned about the cRio... that's a fairly heavy (and expensive!) item to be held on only with zip ties - I'd be concerned that the zip ties would break and let it bounce around inside your robot.
2016: Lake Superior WFFA
Unread 21-01-2014, 17:06
FRC #4505
The CRio actually has two toggle bolts on it currently and then zip ties on the side. Thanks for your help!
Unread 21-01-2014, 18:14
pfreivald's Avatar
AKA: Patrick Freivald
We've used industrial strength Velcro for years....
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 22-01-2014, 00:36
yash101 yash101 is offline
AKA: null
We also use a lot of velcro because swapping out components on the fly is a no brainer, this way! Next would be to make docking connectors so you just place the component down and it's wired up!
Unread 22-01-2014, 00:40
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
There's just something about strapping my electronics with velcro that gives me a horrible feeling.
I'm sure it works, but it seems sort of crude to me. Not refined. Incomplete. Lacking elegance.
For all intensive purposes, I'm sure it works and works fine - and swapping is probably nice - but I like my electronics board pretty
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 22-01-2014, 00:57
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Instead of doing something like that to swap parts quickly, you could just add on extras of vital parts that need little work to be changed out (motor controllers come to mind). For other stuff like the PDB, DS, and cRIO, you'd be spending a lot of time detaching all of the wires in the first two cases and well... I wouldn't velcro on a cRIO and just roll with it.
It is personal preference, but I like bolting down electronics.
Unread 22-01-2014, 07:59
We have used tywraps exclusively for the cRio and other electronics. Let's face it they are insulated. However, small tywraps are not appropriate and more than one set is required. The cRio should not move when you push it from side to side. If you have empty slots, pass a set of tywraps through the holes of the unused slot to be sure the cRio doesn't move.
Unread 22-01-2014, 19:22
AKA: null
Actually, vecro works quite well and also looks quite elegant because everything is behind the part. I think it is nice to relocate a part while you are trying to troubleshoot it. Also, our team uses bolts for the cRIO. We use zip ties to tie the DS to the cRIO
Unread 22-01-2014, 19:30
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Velcro can be very elegant if you do it correctly. Everything all the electronics in the attached image are velcroed down. Wiring isn't the best, but it's no less elegant than bolts, but so much more convenient.
This was 907's 2013 robot.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
