I´ve searched on the game manual but it doesn´t specify if how many, does that mean as much as we want??
Re: How many cameras can the robot have?
I do not think that there is a camera limit. However, there is weight, power draw and available bandwidth that will haunt you if you have more than ~2-3 cameras!
thanks
You're welcome! What competitions are you going to? Are you attending the Phoenix Regionals?
No, there will be a regional here in mexico
Power draw: I've read the power that a webcam uses is about 125 mW. If you limit your cameras power consumption to 40W, which is less than a single motor can use, then power isn't a limit until you have 320 cameras. Bandwidth: Cameras can be configured not to send data back to the driver station. Therefore the available bandwidth can support an unlimited number of cameras. |
#7
Has no one remembered the cost limit? BTW, all cameras even those not used for robot function, must be securely mounted to the robot.
Duct Tape is not a fastener. |
#8
Since the camera is a KOP item, isn't it exempt from the cost limit?
#9
The question wasn't "how many KOP cameras".
#12
There are limits as in outside cost and bandwidth used. You can have 1000 cameras that were 1 penny each and all displayed one pixel so little bandwidth is used and that will be fine.
#13
9001 cameras
#14
You can have an indefinite number of cameras, the bandwidth is not an issue if you switch between camera feeds and/or do all image processing on board. I have heard of multiple teams using a raspberry pi for image recognition.
#15
You would need one hell of an Ethernet switch to support 9001 cameras (perhaps an entire server rack) |
