Go to Post I am as certain as can be on this issue ... believe me. - Paul Copioli [more]
Unread 21-01-2014, 19:00
ElectricNoodle's Avatar
ElectricNoodle ElectricNoodle is offline
AKA: Ted Pabst
FRC #2789 (TEXsplosion)
ElectricNoodle is an unknown quantity at this point
Programming a 6 Motor Drivetrain
This is my first year programming in Labview, and I'm still trying to get the hang of it. Our team is building a 6 cim motor tank drive, but in my projects "begin" VI it will only account for either 2 or 4 motors, is there a way I can make it account for all 6 drive motors?
#code on code on code
Unread 21-01-2014, 19:18
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Programming a 6 Motor Drivetrain
For a tank drive setup, the cRIO only needs to output 2 different speeds to the motors (one for each side.) While you do need one motor controller per motor on the robot, you can use PWM Y-cables so that all three motor controllers on a side get the same signal from the cRIO. Then you can just use a 2-motor setup in the code.
Unread 21-01-2014, 19:32
AKA: Ted Pabst
Okay I think I understand it now.
Thank you for clarifying
