Go to Post You earn what you work for. - Akash Rastogi [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-01-2014, 19:12
CptChaos_III CptChaos_III is offline
Team Captain
FRC #4824 (Berrybotics)
CptChaos_III is an unknown quantity at this point
The FRC limitations for a high load spring
Does the FRC have any load limitations for springs?
Unread 21-01-2014, 19:13
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: The FRC limitations for a high load spring
I believe the only limitation is that it must be used in a safe implementation.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 21-01-2014, 19:15
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
In general, anything the manual does not explicitly prohibit is legal. In this case there is no number that limits springs, but please keep safety in mind.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 21-01-2014, 20:15
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
It has been my experience that when going through inspection with a robot with a spring the inspectors are mostly concerned with what steps we took to contain the spring in the event of a catastrophic failure, not too different than the shielding placed over the shooter wheels of robots last year.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 21-01-2014, 20:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I've had similar experiences with stored energy devices. (Pre-Charged Pneumatics and Springs)
The primary concerns are those relating to safety, specifically safety measures are in place to prevent injury should the spring fail, and how well designed/thought out/well made the 'locking' device was, and if it was possible for the locking device to fail.
Your results may vary, but assuming that you've done your homework regarding the spring's loading and it's attachment/release mechanism, you shouldn't have a problem. If you can produce documentation to show that whatever mechanism you've built was designed to handle the loading, or that whatever parts you've purchased can handle the loading (say, if you're using a COTS latch of some kind), even better. Now, if you're using a run of the mill gate latch to hold back a few hundred pounds of force, and the latch wasn't intended to stop anything more than 50-60lbs, you're going to have a problem...
Also, regardless of the forces involved, it's a good practice to have some sort of 'lock out' plan in place for when the robot is being moved to and from the field, or any other time where a mechanism may be loaded, but not necessarily 'in use'. Something along the lines of a locking pin, or a 'remove before flight' pin is a good idea, especially if it's something that's rated well in excess of the worst case loading involved.
-Dustin Benedict
