Go to Post Most of all, I long to give others a chance to experience what I did with FIRST, to give people from my home town that opportunity, because FIRST really is that once in a lifetime opportunity that so many people dont get a chance to be a part of. It shouldnt be that way. - Jacqui Sutton [more]
Unread 12-02-2003, 09:41
cammie825 cammie825 is offline
#0825 (Maximum Velocity)
cammie825 is an unknown quantity at this point
Send a message via ICQ to cammie825
And yet, ANOTHER questions
I know you guys are thrilled to hear another question for me. But, forgive me, I'm truly not very good at this. And at the crucial moments, I am able to think even less...
I have this compressor code. If anyone can find something wrong with my syntax, or something else, please let me know.
Thanks!
high_pressure VAR rc_sw2
compressor VAR relay3_fwd
pressure_check:
If high_pressure = 0 THEN compressor_go_on
If high_pressure = 1 THEN compressor_go_off
compressor_go_on:
compressor = 1
goto end_pump
compressor_go_off:
compressor = 0
goto end_pump
end_pump:
Unread 12-02-2003, 10:01
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
The first thing I notice is that the pressure switch values are reversed. The pressure switch is normally closed, and opens when the system pressure reaches 115 psi. So I would change your code like so:
If high_pressure = 1 THEN compressor_go_on
If high_pressure = 0 THEN compressor_go_off
(I think I would also change the pressure switch alias to low_pressure instead of high_pressure.)
Unread 12-02-2003, 10:36
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
Re: And yet, ANOTHER questions
Originally posted by cammie825
pressure_check:
pressure_check:
If high_pressure = 0 THEN gosub compressor_go_on
If high_pressure = 1 THEN gosub compressor_go_off
i believe you forgot the gosub command. i may be wrong though.
Unread 12-02-2003, 10:54
Actually wasn't my fault
The team has a problem with blaming all mistakes on the programming. This time, my friend, it was the electrician's fault... haha.. Oh well.
Thanks anyway!
Unread 12-02-2003, 12:39
easier code (even though your's does work)
compressor = high_pressure
Unread 12-02-2003, 16:02
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Re: Re: And yet, ANOTHER questions
Originally posted by yangotang
pressure_check:
Using the gosub command makes the label act as a subroutine. In otherwords, you are able to use the return command to go back to where you left off. In an if then statement, any label stated after the then is considered to be a goto statement. The goto command simply jumps to the corresponding label and does not allow usage of the return command.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 13-02-2003, 00:37
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
question
Originally posted by gwross
if the pressure is high, why would on want to turn on the compressor? Subsequently, if high_pressure = 0, meaning the pressure was not high, wouldn't you want to turn on the compressor, not turn it off? cammie got it right in the beginning. but joe ross does have a point on how to make the code easier, though i would change it to this:
compressor = ~high_pressure
~ being the symbol for NOT
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 13-02-2003, 00:49
the switch is closed (1) when it is below pressure and open (0) when it is full. See the pneumatics manual
we have switches provided by the Nason company. These switches are normally closed. The switches open at approximately 115 psi and will close again at approximately 95 psi
thus, compressor = high_pressure is correct. do not use the ~.
Like gwross said, the variable name high_pressure is a misnomer. It is a 1 when low pressure, and so should probably be called low_pressure
Unread 13-02-2003, 14:48
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Don't get discouraged! Programming (like just about everything else) takes a lot of practice to become good at it. The more you do it, the more natrual the thought process and the more natrual the code will come. Places like this message board are great places for getting your code checked and for even some old(er) hands at this to learn something new
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
pre-inspection preparation questions Adams High Man OCCRA 7 22-10-2002 22:22
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
