Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 22-01-2014, 08:23
alexander.h's Avatar
alexander.h alexander.h is offline
Lead Programmer, Captain, Driver
FRC #3975 (The Dragons)
alexander.h has a spectacular aura aboutalexander.h has a spectacular aura aboutalexander.h has a spectacular aura about
Re: We Need Serious Robot Help!
Originally Posted by cgmv123 View Post
Which 2 are solid? Are they on the same side or different sides?
Flashing orange means the Talon isn't getting any signal. Solid orange means the Talon is getting a signal, but it won't output anything since that signal is 0.
If it's flashing, it could be a code issue or a wiring issue. If it's solid, it's most likely a code issue, since the code has to be the one to send the Talon a signal of 0.
I don't think this is the issue, but replace your battery with a fully charged one just to be sure.
My bad, all three are now and changing the battery doesn't work either.
2012 - Rebound Rumble - Montreal Robotics Festival - Qualified 15th - Semifinalists thanks to 3379 and 3710 (Record : 8-8-1)
2013 - Ultimate Ascent - Montreal Robotics Festival - Qualified 33rd - Dean's List Finalist : Yazid Djenadi (Record : 4-8-0)
2014 - Aerial Assist - Montreal Robotics Festival - Qualified 9th (Record : 6-4-1)
2015 - Recycle Rush *** I predicted the game ***
