Go to Post Drive yourself, ride Amtrak or Greyhound bus, or bend space-time to the point of singularity and you'll just poof into existence in Atlanta. - artdutra04 [more]
Unread 22-01-2014, 08:34
magnets's Avatar
magnets magnets is offline
Re: We Need Serious Robot Help!
We really need pictures to help you. Somebody on your team must have an iphone with camera who would be willing to take a picture for you.
Anyway, the flashing orange light on the talon means the talon has power, but no signal. If you're using the code posted earlier, which is correct, and you followed joe's advice to remove all cables but the power one and confirmed that all three leds are lit, then you need to check your pwm cable. Is it plugged in the right way? Try flipping the connector. Is it plugged in all the way?
The solid orange light means that your code is wrong (make sure you copy what was posted) or your driver station isn't recognizing your joystick. Under the diagnostic tabs, what color does the joystick 1 indicator turn when you push a button?
