Go to Post free hugs-one size fits all - joshsmithers [more]
Unread 21-01-2014, 18:49
Rafa12 Rafa12 is offline
FRC #3472 (Buluk)
Rafa12 is an unknown quantity at this point
Question How many cameras can the robot have?
I´ve searched on the game manual but it doesn´t specify if how many, does that mean as much as we want??
Unread 21-01-2014, 18:51
yash101 yash101 is offline
AKA: null
Re: How many cameras can the robot have?
I do not think that there is a camera limit. However, there is weight, power draw and available bandwidth that will haunt you if you have more than ~2-3 cameras!
Unread 21-01-2014, 18:55
FRC #3472 (Buluk)
thanks
Unread 21-01-2014, 19:00
AKA: null
Originally Posted by Rafa12 View Post
thanks
You're welcome! What competitions are you going to? Are you attending the Phoenix Regionals?
Unread 21-01-2014, 19:08
FRC #3472 (Buluk)
No, there will be a regional here in mexico
Unread 22-01-2014, 03:23
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Weight: A small camera is under a pound. You would not run into this limit until you had like 100 cameras.
Power draw: I've read the power that a webcam uses is about 125 mW. If you limit your cameras power consumption to 40W, which is less than a single motor can use, then power isn't a limit until you have 320 cameras.
Bandwidth: Cameras can be configured not to send data back to the driver station. Therefore the available bandwidth can support an unlimited number of cameras.
Unread 22-01-2014, 07:56
Has no one remembered the cost limit? BTW, all cameras even those not used for robot function, must be securely mounted to the robot.
Duct Tape is not a fastener.
Unread 22-01-2014, 09:44
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Since the camera is a KOP item, isn't it exempt from the cost limit?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 22-01-2014, 09:52
Nate Laverdure's Avatar
FRC #2363
There was a maximum quantity of 1 per team for the AXIS M1013 on FIRSTChoice. Doesn't this mean that only 1 unit can be exempted from the total cost limit?
Unread 22-01-2014, 12:23
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
R10 Blue box says KOP items are exempt in any quantity.
Unread 22-01-2014, 12:37
The question wasn't "how many KOP cameras".
Unread 22-01-2014, 16:46
bulbajackel's Avatar
bulbajackel bulbajackel is offline
Programmin fo dayz
AKA: Chuck
FRC #2408 (Shrapnel Sergeants)
bulbajackel is an unknown quantity at this point
There are limits as in outside cost and bandwidth used. You can have 1000 cameras that were 1 penny each and all displayed one pixel so little bandwidth is used and that will be fine.
"It's the programmer's fault"
Unread 22-01-2014, 18:20
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
9001 cameras
2015 MAR District Champions
Unread 22-01-2014, 20:01
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
You can have an indefinite number of cameras, the bandwidth is not an issue if you switch between camera feeds and/or do all image processing on board. I have heard of multiple teams using a raspberry pi for image recognition.
Unread 22-01-2014, 20:14
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by dubiousSwain View Post
9001 cameras
You would need one hell of an Ethernet switch to support 9001 cameras (perhaps an entire server rack)
