Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 21-01-2014, 16:39
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Exclamation Imaging help!
I am very confused with an issue that came up when I was imaging our new cRIO. The imaging tool recognized the cRIO, but my FRC_ImageVersion.ini file is missing. Can anyone tell me where I can get this file? I could not find it in the update, or anywhere else. Am I the only one with this issue? please help!
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 21-01-2014, 17:28
katsauga's Avatar
Lead Programmer
Exclamation Re: Imaging help!
I need help Whenever Possible
Unread 21-01-2014, 22:45
Re: Imaging help!
What is telling you the file is missing? Can you not proceed with the imaging process without it? I thought FRC_ImageVersion.ini was a file on the cRIO itself.
Unread 22-01-2014, 11:18
katsauga's Avatar
Lead Programmer
Re: Imaging help!
Well, When I go to launch the image process, it come up with an error saying "file missing from directory C:\users\user\AppData\Local\Temp\lvtemporaryd_2094 78\FRC_ImageVersion.ini please enter alternate directory, or check that the file is there using windows explorer or command prompt."
Unread 22-01-2014, 11:25
Re: Imaging help!
It looks like the installation of the FRC tools didn't quite work. Try rerunning the 2014 FRC update.
Make sure you extract everything from the .zip file first before running the setup.exe program. Installing directly from inside a compressed archive often fails to work properly.
Unread 22-01-2014, 11:43
Re: Imaging help!
I have seen that failure when the imaging tool is not able to FTP to the robot. This can happen when the IP address of your computer is misconfigured or when a firewall is blocking FTP.
Unread 22-01-2014, 11:58
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Re: Imaging help!
Not sure if firewall and anti-virus software are the reason, but temporarily disabling them has solved some of the issues related Radio and cRIO setup. Sometimes power cycling the whole system, radio, cRIO, Windows based PC/laptop helps too!
Unread 24-01-2014, 13:20
katsauga's Avatar
Lead Programmer
Talking Re: Imaging help!
Thanks for all the help! We fixed the problem and our robot is working now, THanks!
Unread 24-01-2014, 13:28
Re: Imaging help!
It would help other people in the future if you posted what you did to fix the problem.
Unread 24-01-2014, 15:50
katsauga's Avatar
Lead Programmer
Re: Imaging help!
We had trouble with an I.P. conflict, but we fixed that.
