Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-01-2014, 12:18
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Omni Wheel Configuration
a couple of files from previous CD posts (credits are in the files) that I think you will find useful in your trade-off analysis.
Unread 22-01-2014, 13:01
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by Nate Laverdure View Post
Note that this description isn't sufficient for describing a holonomic drivetrain based on omni wheels. For example, the attached design is not holonomic (source image).
Wikipedia seems to disagree.
http://en.m.wikipedia.org/wiki/Holonomic_(robotics)
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 22-01-2014, 13:18
Nate Laverdure's Avatar
FRC #2363
There's no disagreement. With the design I posted, you'd be able to control only 2 of 3 DOFs.
Unread 22-01-2014, 13:27
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I see. The attached differs from the source.
Kevin Li
596 - Sciclones
Unread 22-01-2014, 13:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
A pragmatic suggestion: seriously consider how reasonable it would be for your team to successfully execute a holonomic drivetrain, for what sounds like the first time ever, starting half-way through Week 3 of build. Your drivetrain is the single most important sub-system on your robot, thus I strongly encourage you to use a low-risk approach.
