Go to Post Commence the year of the brown out! - Jared Russell [more]
Unread 21-01-2014, 17:46
DarthMaulCIS DarthMaulCIS is offline
FRC #4607
DarthMaulCIS is an unknown quantity at this point
Errors When Deploying to Simulator
"Block Diagram Errors
Wire connected to an undirected tunnel.
This wire connects one or more data sinks but has no source."
This shows up when I try to deploy my code to the simulator. I think it is because I have code in my begin that I don't have corresponding pieces to in teleop, but I'm not sure. I can email you guys our code so far if you want to help.
Unread 21-01-2014, 18:14
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
Re: Errors When Deploying to Simulator
The broken wire indicates that "error out" from begin.vi is missing. Copy an error cluster from another vi and paste it into begin.vi. Then change it to an indicator and hook it back up the VI's terminal.
This is what the front panel of your begin.vi should look like.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 21-01-2014, 22:55
You didn't delete any of the code connected to the original Joystick Open from Begin.vi, did you? That'll break Robot Main. There really should be something on the block diagram labeling that "error out" indicator as an essential component of the framework.
Follow the previous post's directions to add it back in, and things should work again.
Unread 22-01-2014, 17:20
FRC #4607
Thanks guys, I borrowed another begin.vi and started it fresh. Working now. And I didn't know that error out was important. my bad.
