Go to Post Some of us should be so lucky to have something go wrong on Einstein. - Kevin Sevcik [more]
Unread 22-01-2014, 19:23
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Custom Intake Rollers
I'm curious about what other teams are using for rollers on their intake system for 2014.
I'm primarily interested in custom made rollers and what has worked best for controlling the canvased game ball. (Any experience from 2008 is also welcome).
So here are my questions.
What type of roller material are you using?
Was it expensive?
How are you driving it?
Are you using some type of traction material on it?
If so, what type?
Are you using polly cord?
If so how are you controlling the pollycord? (Lathing grooves, building up area around the cord)
Are you using wheels?
If so what type of wheels?
Thanks in advance!
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 22-01-2014, 23:42
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Custom Intake Rollers
As soon as we got the ball into the shop I did the good old touch stuff to the ball test. I highly recommend doing this test around your own shop. We found that the BaneBots wheels, which are relatively inexpensive, gripped the ball best. They are also particularly nice because the ones we have are hex on the inside. All we have to do is run the shaft through them and drive the shaft with a motor which is chained to a sprocket, also hex, which sits on the shaft, and we have our roller.
I hope that helps.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 23-01-2014, 01:49
Chris is me's Avatar
AKA: Pinecone
Our tests showed the two best materials for gripping the ball were Banebots wheels and sorbothane. We went with Banebots wheels because of the hassle of installing and cleaning sorbothane tread wheels, but we will use strips of sorbothane elsewhere on the claw.
Unread 23-01-2014, 02:40
Michael Yeh Michael Yeh is offline
Lead Chief Delphi Lurker & CAD/Mech
FRC #4099
Michael Yeh is an unknown quantity at this point
Where do you source your sorbothane? Is it this from mcmaster or is does it come in a more convenient form (rollers,wheels?)
Otherwise we were considering 3M gripping material or the McMastered rubber strips that Boom DONE used.
Unread 23-01-2014, 02:51
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
We're finding some success with the DT versawheels on our intake. For smaller diameter rollers though, we use Polyurethane tubing found here. This material is very grippy, and can be compressed quite a bit as well.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 23-01-2014, 10:25
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
My team machines our own conveyor rollers. In prototyping we used 2 inch OD PVC pipe and machined hubs that press into either end. We drilled two holes through the PVC drum (at either end) and spiral wrapped urethane cord (AKA polycord) around the roller using the holes as positions for anchoring the ends. It worked beautifully. On the final bot the rollers will be made with .065 wall aluminum tubing instead of PVC.
Unread 23-01-2014, 10:48
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Like others have said, BaneBot wheels are awesome. Back in 2008 (before Banebot had wheels, I believe) we did custom rollers - plastic wheels with some sort of foamy rubber glued on. It was a huge mess though - the rubber was constantly coming off in chunks, and we had to have a couple spare sets of wheels so we could swap them out and fix them with new rubber. I would definitely go with a more off-the-shelf solution!
2016: Lake Superior WFFA
Unread 23-01-2014, 23:53
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This was our original thought.
After some testing we noticed that there was a weird spin on the ball and concluded that it was because of the larger wheels spinning faster than the smaller wheels. To solve this we settled on using the 2.875" wheels all the way across and it works much better.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 24-01-2014, 00:56
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We are using rubber jar stoppers that we got at our local hardware store. They have a slight bevel and are about 2" in diameter. They are working well in early testing.
Unread 25-01-2014, 01:07
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
We use 3" black ABS sewer pipe with some grey 3M bathtub anti-slip tape wrapped around it. This stuff is found at some Ace Hardware stores in various widths, sold by the foot. It's not the black sandpaper stuff, but rubber with a high texture.
We drilled bearing holes in the end caps on the lathe. Our nice build space, Xerocraft, has a shiny new 7/8 drill bit lying around, bless their hearts.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 25-01-2014, 12:48
AKA: Pinecone
This is what we ordered. We got the 1/4" thick stuff. To install it on a wheel we just wrapped it around the wheel, held it temporarily with masking tape, used a pokey tool to stab rivet holes into it, and used big head rivets to fasten it. A strong contact adhesive may be a better idea though.
Unread 25-01-2014, 14:16
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
How can you secure the wheels in place on the hex shaft? AndyMarks is out of stock of the hex shaft collars.
Unread 25-01-2014, 15:27
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
kuraikou is an unknown quantity at this point
4183 is using ABS tubing because it works, and it is so easy to work with.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 26-01-2014, 13:34
Lead Bumper Mentor
AKA: Mike Marandola
We are using PVC spacers to keep the spacing between the wheels and turned down the ends of the hex shaft to fit in 3/8" bearing blocks and collars.
Unread 26-01-2014, 14:12
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
Here on thingiverse is a scad for 3D printable shaft collars that will accept Hex Shafts.
http://www.thingiverse.com/thing:228005
We have also developed this scad for shaft couplers:
http://www.thingiverse.com/thing:229161
I would print this in Nylon however and on it's side as hex for strength.
The parametric wheel was used to create spacers.
http://www.thingiverse.com/thing:234935
Depending on how well your printer is calibrated I use 13-14mm for the shaft diameter to fit the 1/2" shaft snugly.
