Thread Tools |
Rating:
Display Modes |
Last year we tested 5 and used the one with the highest pressure. They are factory set. Best you can do is order a few more test them and cross your fingers.
Re: Calibrate Pressure Switch?
You might try putting the pressure switch far away from the compressor, so it is less likely to see momentary peak pressures that are above the steady-state pressure. For example, it might help to put it on the other side of the storage tanks from the compressor, if you can do so...
You can adjust them. Not to be done lightly, but your robot inspector will check it during inspection. PM me for directions if you need them.
Frank, would you mind sharing how to adjust the switch? We've tried 4 switches and they are all shutting off around 106 PSI.
Pressure switches cannot be calibrated. They come as they are and not all are alike. Big Al posted somewhere that if it is cutting off early like that then it could be an old one that is starting to fail. Try moving farther from the compressor (still on 120PSI side) or a new switch.
Frank I believe that you are thinking of the pressure relief valve. |
That's what I thought too - as far as I knew the pressure switch is a sealed unit that doesn't take kindly to being disassembled.
#7
Have you tried a different gage? If 4 switches are reading the same I would suspect the gage is bad.
#8
Calibrating the pressure switch is possible. There is a setscrew on the side which is allen head, the manufacturer has originally set them and put silicone around the threads where the plastic meets metal base. That is what the set screw is for. Take a utility knife score the silicone and peal it out. Loosen setscrew pressurize system, adjust pressure switch by threading the top and bottom half in or out (A little adjustment goes a long way). Adjust to the proper cut in/out pressure, tighten setscrew, reverify pressures, re-silicone – done.
#9
My gut would say it's not a alteration of the pneumatic part per se, but a calibration of one using a method designed for that purpose. So long as it turns off the compressor at or below 120 and does so consistently I don't see a rules compliance issue. This hinges on whether the GDC/Inspectors interpret it as a alteration or not. It's probably worth a Q&A. |
#11
I did a quick look and nothing states that you have to use the Nason pressure switch either (correct me if I'm wrong). Apparently the nason pressure switch may be ordered in a 120PSI variety as well.
#12
#13
Is calibrating really modifying?
As you are well aware the inspection checklist explicitly requires this switch to be checked that it shuts off the compressor at the appropriate pressure. I see no harm in allowing teams to adjust these rather than forcing them to purchase new ones when a small adjustment will fix the issue. It seems wasteful. |
#14
If you are saying I can't adjust a set screw that is designed to be turned with a screw driver because it is modifying a pneumatic component, then we all have to stop using NPT fittings because they deform when threaded together. And push to connect fittings as well because the o-ring and barbs change shape every time a piece of hose passes through them. |
