Go to Post how can anyone Not Notice An entierly Pink Team? - Tytus Gerrish [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 22-01-2014, 19:03
aciarniello's Avatar
aciarniello aciarniello is offline
AKA: Andy
FRC #4028 (The Beak Squad)
aciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud of
Calibrate Pressure Switch?
Is it possible to calibrate the pressure switch? Ours seems to shut off closer to 105 psi. I would like to be able to carry the maximum capacity of air on board!
Unread 22-01-2014, 19:09
Dale's Avatar
Dale Dale is online now
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Calibrate Pressure Switch?
Sadly the pressure switches are factory set...there's nothing you can adjust. Some will be low, some high.
Unread 22-01-2014, 19:59
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Last year we tested 5 and used the one with the highest pressure. They are factory set. Best you can do is order a few more test them and cross your fingers.
Unread 22-01-2014, 22:59
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
You might try putting the pressure switch far away from the compressor, so it is less likely to see momentary peak pressures that are above the steady-state pressure. For example, it might help to put it on the other side of the storage tanks from the compressor, if you can do so...
Unread 24-01-2014, 23:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You can adjust them. Not to be done lightly, but your robot inspector will check it during inspection. PM me for directions if you need them.
Unread 14-03-2014, 07:16
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Frank, would you mind sharing how to adjust the switch? We've tried 4 switches and they are all shutting off around 106 PSI.
Unread 14-03-2014, 07:55
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Pressure switches cannot be calibrated. They come as they are and not all are alike. Big Al posted somewhere that if it is cutting off early like that then it could be an old one that is starting to fail. Try moving farther from the compressor (still on 120PSI side) or a new switch.
Frank I believe that you are thinking of the pressure relief valve.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 14-03-2014, 08:47
Tom Line's Avatar
That's what I thought too - as far as I knew the pressure switch is a sealed unit that doesn't take kindly to being disassembled.
Unread 14-03-2014, 09:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Have you tried a different gage? If 4 switches are reading the same I would suspect the gage is bad.
Unread 14-03-2014, 11:04
lonnie lascelle's Avatar
lonnie lascelle lonnie lascelle is offline
Team Mentor
FRC #0930 (Mukwonago BEARs)
lonnie lascelle is on a distinguished road
Calibrating the pressure switch is possible. There is a setscrew on the side which is allen head, the manufacturer has originally set them and put silicone around the threads where the plastic meets metal base. That is what the set screw is for. Take a utility knife score the silicone and peal it out. Loosen setscrew pressurize system, adjust pressure switch by threading the top and bottom half in or out (A little adjustment goes a long way). Adjust to the proper cut in/out pressure, tighten setscrew, reverify pressures, re-silicone – done.
Unread 14-03-2014, 11:10
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Does the steps to calibrate the pressure switch fall within R76? It doesn't seem to so I'd be careful about actually doing this.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-03-2014, 12:09
Andy A. Andy A. is offline
Getting old
FRC #0095
The precedent might be that you can adjust the emergency relief valve (and often must) despite it not being an exemption in R76. Then again, the relief valve is governed by R87, which includes a blue box text that explicitly allows for adjusting it. R88, which governs the switch, does not have any similar language. It's sort of a grey area.
My gut would say it's not a alteration of the pneumatic part per se, but a calibration of one using a method designed for that purpose. So long as it turns off the compressor at or below 120 and does so consistently I don't see a rules compliance issue. This hinges on whether the GDC/Inspectors interpret it as a alteration or not.
It's probably worth a Q&A.
Unread 14-03-2014, 12:19
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I did a quick look and nothing states that you have to use the Nason pressure switch either (correct me if I'm wrong). Apparently the nason pressure switch may be ordered in a 120PSI variety as well.
Kevin Li
596 - Sciclones
Unread 14-03-2014, 12:41
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
We are specifically allowed to use other switches; see Q258. Also see http://www.chiefdelphi.com/forums/sh...74&postcount=9
Mentor http://www.teamtitanium.org/
Unread 14-03-2014, 13:09
Tom Line's Avatar
Yep, we tried multiple different pressure gages and they are read similarly (within a psi or two).
