Go to Post There is no feeling greater than being a part of a group that would walk through fire with you. Complete commitment, complete trust, and total respect. - Rich Kressly [more]
Unread 22-01-2014, 20:07
sunny1118 sunny1118 is offline
FRC #0224 (The Tribe)
sunny1118 is an unknown quantity at this point
Bumpers
If i have an opening that is about 24 inches and both sides are 2 inches each and their is a bumper around those two inches is that allowed?
Unread 22-01-2014, 20:19
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Bumpers
There must be 8" of bumpers past each vertex of the robot perimeter. If you wanted a 24" gap in the bumpers, that side of the frame must be 24+8+8=40" long
Originally Posted by Rule 4.6.19
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside corner (see Figure 4-5). If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-6). For the purposes of R19, a round or circular FRAME PERIMETER has an infinite number of corners.
Unread 22-01-2014, 20:22
I am Dave! Yognaut
AKA: Brian Bray
Re: Bumpers
I realize that my previous post is pretty ambiguous when it comes to your case.
The way I interpret the bumper rules is that around the corner of your robot, there must be 8" of bumper flanking that corner, and if there is a break in the bumpers, there must be 8" before the corner
Unread 22-01-2014, 20:26
Re: Bumpers
I thought it said something about how it their can be a gap and if the side is less than 8 in then the whole side has to be covered
Unread 22-01-2014, 21:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumpers
Naturally, you DO know that any opinion you get here on Chief Delphi is as valuable in competiton as the opinion of any random drunk you find on the street.
Nonetheless: a 2" long bumper on a 2" long side of a robot seems OK to me. Looking at the image above, if a side is less than 8 inches, it needs to cover the entire side.
EDIT: Q112 in the FRC Q&A covers this situation, and it says you can have a bumper shorter than 8" ONLY IF that side of the robot is less than 8". For example, a 7" x 47" robot can have 7" bumpers on the short ends. Few teams would implement such a robot, but if you cut the corners and they end up only 6" long, that's OK as long as the bumpers cover the 6" side completely.
Unread 22-01-2014, 22:02
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumpers
Look at Figure 4-5 in the manual, especially the example on the lower left.
There's a cutout in the side, creating a U-shaped frame. The figure shows that the ends of the U must be at >= 8" wide to accommodate an 8" bumper section.
(since 2004)
