Go to Post It will be really cool if it works, sad if if doesn't. We got our fingers crossed! - falconmaster [more]
Unread 21-01-2014, 22:52
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
mecanum drive and joystick
Ok our idea was to use a 4 wheel mecanum drive set up. The issue is its our first time using them so we have no idea how to program it in labview. Problem number 2 is that we want to use the logitech extreme 3d pro controller because of the fact that you can turn the stick. We wanted to use one controller to do all the driving,so forward and backward and to go right and left but to use the twist to spin (or turn the bot left and right). Again we have no idea how to do this or implement it into the code.
So if any one could help and explain it (to beginners) wile having pictures for examples it would be really appreciated .
Unread 21-01-2014, 22:56
Re: mecanum drive and joystick
There's a vi for that in LabVIEW.
Unread 22-01-2014, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
I feel badly posting this, because I don't like to discourage teams from trying things. But:
Meccanum is not trivial to implement, and perhaps you might consider getting some off-season experience with it before committing to it during build season.
Unread 22-01-2014, 22:22
FRC #3993
This is our code but the problem is that (twist right= forward) (twist left= back) (stick forward= spin right) (stick back= spin left'ish) (stick left= right wheel error) (stick right= right wheel error).
Name:	drive help pic.png
Unread 22-01-2014, 22:34
My first thought is that your right wheels are simply spinning in the wrong direction. In the 4 Motor Open function in Begin, there is a place to invert those motors.
Unread 22-01-2014, 22:35
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Check your motor controllers to make sure they are plugged into the correct spots on the Digital Sidecar. If that doesn't help, remember that 2 of the motors must be inverted in Begin.vi for it to work correctly (I generally invert both left motors. If they all function correctly, but the joystick is backwards, then invert the other two instead.) Hover over the Open 4 Motors.vi and you will see 4 green dots (2 on top and 2 on bottom) that reference the inversions.
I'm right 90% of the time, so why worry about the other 3%?
Unread 22-01-2014, 23:35
FRC #3993
Ok ill try that out thank you, also this is my begin if you think there can be any changes.
Unread 25-01-2014, 22:06
FRC #3993
do they have to be set to true or false for to be inverted?
Unread 25-01-2014, 23:50
Cecil's Avatar
AKA: Alex Hummel
True means it is inverted. Basically, you have to do this because motors face the opposite direction on different sides of the robot. The same concept can be achieved by setting all motor inversions to False and swapping the leads of the motor around at the motor controllers on one side of the robot. (Note: Do NOT swap the power leads leading from the Power Distribution board. If you decide to go this route, only swap the leads on the motor side of the speed controller.)
If you are going the code route, two of them should be inverted. Just make sure they are both from the same side (either right or left), not front and back inverted from each other.
Unread 27-01-2014, 00:23
Another thing to check on is the mapping of your joystick axes.
They may not match what LabVIEW is calling axis 1,2, & 3 and it's easy to verify with Joystick Explorer or your own front panel.
Unread 27-01-2014, 20:14
FRC #3993
ok so it now works but how do I get it to go diagonally?
Unread 27-01-2014, 20:33
Cecil's Avatar
AKA: Alex Hummel
Diagonal movement is a combination of left/right and forward/back motion. Try pushing your joystick to the upper left or right corner. It should move diagonally in that direction.
Unread 27-01-2014, 23:02
FRC #3993
lol yah we found that out. Thank you for all the help and thank you for dealing with my stupid questions.
Unread 27-01-2014, 23:17
Cecil's Avatar
AKA: Alex Hummel
No problem. That's what we are here for.
