Go to Post The term normal is relative to CADer side of me. When compared to the rest of society, there is no normal side of me. - Pault [more]
Unread 22-01-2014, 09:07
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
pic: 5107 CAD Progress
Unread 22-01-2014, 09:08
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: pic: 5107 CAD Progress
That is soooo nice. Great job on the CAD.
Unread 22-01-2014, 11:29
md2377 md2377 is offline
FRC #2377
md2377 is an unknown quantity at this point
What CAD program did you use for that rendering?
Unread 22-01-2014, 12:31
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Awesome Design! I like its simplicity. I assume the claw can be rotated near vertically to fit within the frame perimeter?
Unread 22-01-2014, 12:38
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
When you lift your arm up, is the ball only supported by the two bottom posts, or is there another mechanism not included in the render? If so, what happens if a robot runs into you after you lift your arm up? What happens if you come to a quick stop?
Unread 22-01-2014, 14:20
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Not sure what they used, but Inventor can do Ray Tracing.
Unread 22-01-2014, 15:04
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Your design looks similar to ours in a few ways. Very slick, but you might want to make sure that your puncher will hit the center of the ball. (unless you're trying to put spin on the ball)
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 22-01-2014, 15:13
Dr.Gusta's Avatar
Team Role: CAD
Thank you guys do much for the positive comments. As for holding the ball tightly yes it only rests on the two forks. We did some testing and it holds it quite securely. Yes the ball will fall out if we get hit hard but we were willing to sacrifice that to keep our design simple. As for the puncher hitting center I did the math so that the puncher hits the ball dead center. Lastly this was all drawn in Autodesk Inventor. You can make it look nice like this in the view menu while in your final assembly. Then turn on shadows reflections and change shading to realistic which turns on ray tracing. Then change the scene from two lights to what ever you want.
Unread 23-01-2014, 00:36
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
This is a great render!
I was wondering, have you had better luck testing with surgical tubing than with springs, or vice versa?
We tried many types of springs, and found surgical tubing to be the most practical choice for this application.
Also, did you think of different disk sizes for the puncher? Because that can affect shooting efficiency. The more surface touching the ball, the better.
Unread 23-01-2014, 00:42
And/or the 20" allowance?
As a reminder, you have to be inside the frame perimeter at the start, and within 20" horizontally of it during the rest of the match. You're looking mighty close to that, though some of that might just be the angle.
BTW, I see a distinct similarity to a robot that is in the top 3 of all time in FRC. That, along with the detailed CAD, kind of scares me--in a good way, of course! I'll have to check y'all out in Inland Empire.
Unread 23-01-2014, 13:30
Dr.Gusta's Avatar
Team Role: CAD
WOW top three robots in FRC history that is intense did not know there was a hall of fame I will have to check that out. We tested both springs and surgical tubing and had success with both so we made it so both can be used. As for the 20" extending from the frame perimeter it is two inches under and that was not by accident either lol. Thank you for all of the positive support really means a lot coming from veteran teams.
Unread 23-01-2014, 19:45
Actually... (and I might have to talk this over with ya in person), the Hall of Fame doesn't include robots. Membership is restricted to Championship Chairman's Award winning teams.
On the other hand, the all-time top 3 ROBOTS is a bit of an informal "who do you think?" type of discussion, and generally includes team 71 in 2002, and tends to include 1114 in 2008 (which is the one I was referring to); the third robot is under debate from time to time, but nobody really has an answer. Yet.
