Go to Post Is it legal to build 2 robots? yes. Is it crazy to do so? maybe. - Andy Baker [more]
Unread 23-01-2014, 00:34
Gearheads1 Gearheads1 is online now
AKA: Brian Holmgren
FRC #4455 (The Burger Bots)
Gearheads1 is an unknown quantity at this point
Banebot Wheels 1/2 inch keyed shaft
I've tried to figure it out on the Banebots site and can't. Do Banebots 1/2 shaft keyed wheels require shaft collars to keep them in place with their keys, or are there set screws on the wheels? Thanks for your help!
Unread 23-01-2014, 00:39
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Need to add retention. No set screws.
Unread 23-01-2014, 00:41
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Banebot Wheels 1/2 inch keyed shaft
I'm not 100% certain however my team did use banebots wheels last year (we bought them un-broached though, it was cheaper to do it ourselves) and they did not have setscrews. I would assume that the broached ones would be the same.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 23-01-2014, 08:09
AKA: Brian Holmgren
Thanks!
Unread 23-01-2014, 11:23
To clarify:
Half inch keyed round and half inch hex versions of the wheels both come without set screws and without a place to put set screws.
You can retain them with shaft collars, c clips, e clips, bolts/washers, cotter pins, expanding axle, bolts/washers into the axle, etc. Or just use a tapered, oversized key.
I don't think that modifying them for set screws is a good solution. Getting some of the banebots hubs might give you additional options.
Unread 23-01-2014, 21:34
AKA: Brian Holmgren
Thanks, we ordered shaft collars to keep them in place.
