Go to Post a robot that is broken shows that it has survived more than a robot that doesn't even have a scratch. - robot180 [more]
Unread 23-01-2014, 09:32
theonlydvr theonlydvr is offline
FRC #4338
theonlydvr is an unknown quantity at this point
Axis Camera Exception: No Image Available [Answered]
Hey all,
I've recently encountered a problem in saving images from the axis camera (M1101). I setup the camera according to instructions and it is working perfectly fine in every other aspect. I get a stream to the dashboard and it can be successfully pinged. However, when I try to use the getImage() function in my code I get an AxisCameraException saying no image is found even though the SmartDashboard is streaming well.
This is my code (very simple):
try
    Axis.getInstance("10.43.38.11").getImage().write("image.jpg");
catch (AxisCameraException ace)
    ace.printStackTrace();
catch (NIVisionException nive)
    nive.printStackTrace();
Thanks,
Evan Dastin-van Rijn
Unread 23-01-2014, 09:35
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Axis Camera Exception: No Image Available
Once you get the instance of the camera it takes a few seconds to actually complete the connection, so for about 5-7 seconds after getting the instance no images will be available. Try getting the instance of the camera in robotInit and accessing it from there. We ran into this problem on Tuesday and that fixed it for us.
Unread 23-01-2014, 09:41
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
This is also what we experienced. When you see something like "ClassName.getInstance()", it's an example of the Singleton Pattern. The first time it is called, the object is constructed, so it takes a little bit of time (see the Lazy Initialization section of the link). calling getInstance() later should be pretty quick, though.
Unread 23-01-2014, 10:23
FRC #4338
Thanks so much for the replies!
I am no longer getting the exception however when I ftp to the cRIO (10.43.38.2) in my browser "image.jpg" doesn't show up. Am I correct in thinking the .write() function for Image writes tot he home directory of the cRIO and if not where does it save to?
Thanks,
Evan
Unread 23-01-2014, 10:49
FRC #4338
Smile Re: Axis Camera Exception: No Image Available
Never mind, I figured it out. I found where the image was saved: 10.43.38.2/ni-rt/system. Thanks for all the help again!
