Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Unread 23-01-2014, 10:35
Aren_Hill's Avatar
Build Nifty Things
Re: Vex Planetary Carrier (versaplanetary)
Originally Posted by Andrew_V View Post
Last month,
While taking apart a versaplanetary I have discovered the pins on the carrier have slipped out and has started scratching the back housing. This is a 10:1 versaplanetary. I have pressed the "pins" back in and plan to later on to come back and clean and add retaining compound.
images here: (images too large to upload directly)
http://minus.com/mifBeJc2DJVbh
Has anyone encountered this?
AndrewV
Andrew,
I have pushed some 10:1's to this point before, large shock loads make this start happening. The pins on the 10:1 are so close to the spline that this is the failure mode/the plate may also crack.
Obviously the CIM and Mini-CIM are use at your own risk, otherwise the loading guide is your friend.
-Aren
A guy who likes robots.
