Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Thread Tools Rating: Thread Rating: 22 votes, 4.95 average. Display Modes
Unread 22-01-2014, 23:50
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Best Way to Tie Off Surgical Tubing
Hello CD world,
We are planning on using surgical tubing this year for our launching mechanism. We have been tying the surgical tubing in knots, but with the extreme stress we are putting it under the knots are slipping bit by bit. I was wondering if any people with a lot of experience with the stuff could advise us and other FIRST teams on the best way to tie the stuff. I have seen a few posts mentioning zip ties and hose clamps, but can't be certain if there is any trick to securing this stuff.
Thank you
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 23-01-2014, 00:02
stryker0603 stryker0603 is offline
AKA: Jordan Smith
FRC #0314 (Megatron Oracles)
stryker0603 will become famous soon enoughstryker0603 will become famous soon enough
Re: Best Way to Tie Off Surgical Tubing
The method that the teams I have been on is to use zip ties to hold them together. The trick is to stretch the surgical tubing so that the zip tie is tightened when the tubing is as thin as it will be so it doesn't slip.
Unread 23-01-2014, 00:03
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Using zip ties with a zip tie gun ensures that they are tight. Pretty easy to find one relatively cheap.
http://www.uline.com/Product/Detail/...A&gclsrc=aw.ds
Unread 23-01-2014, 00:28
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Hose clamps might be the way to go for a COTS component. The ability to have them adjust tensioning with minimal effort is a solid way to go. Also, replacements for new surgical tubing in the same clamps would take much less time than with zipties.
The only issue I could see with them is that they would be too sharp and the recoil might sever the tubing which would drastically increase performance overtime. However, adding some material to reduce the catching of that edge can certainly be done.
In addition, clamping the tubing after a point where it has attained some friction is much better than to the final stretched position.
Edit: Apparently the end of my third sentence was cut off.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 23-01-2014, 00:41
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Bolt two flat blocks together. Sandwich the surgical tubing in between.
Unread 23-01-2014, 01:36
brianbond's Avatar
brianbond brianbond is offline
Head Coach
AKA: Brian
FRC #5102 (The Underbots)
brianbond has a spectacular aura aboutbrianbond has a spectacular aura about
Zip Ties work great. We have put lots and lots of stress on our surgical tubing and the Zip Ties have not shown any real weaknesses.
Unread 23-01-2014, 01:49
AdamHeard's Avatar
Lead Mentor
What Cory is getting at is make a capstan of sorts;
http://en.wikipedia.org/wiki/Capstan_equation
Wrap the surgical tubing a few times around something and the clamping force required afterwards is a fraction of the loaded tension.
Unread 23-01-2014, 01:50
Chris is me's Avatar
AKA: Pinecone
In 2011 when we balanced our arm with tubing, we doubled back the tubing about six inches and installed several zip ties, pulling them all tight with pliers. The system never slipped, just be sure those zip ties are TIGHT.
Unread 23-01-2014, 01:53
GUI GUI is online now
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
What kind of knot have you been using? We haven't had any problems using a euro death knot. Also, you can reduce the load on whatever joint you use by using more individual strands in parallel.
Unread 23-01-2014, 02:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Don't tie knots in surgical tubing, they are nearly impossible to remove. Zip ties work just when you pretension the surgical tubing, and are much more easily removed when compared to knots.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-01-2014, 09:52
What's wrong with the obvious way?
(do NOT lubricate)
Unread 23-01-2014, 11:05
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
I agree with the zip tie solution. Knots can be incredibly difficult to remove, plus, in my experience, creates wear on that point of the tubing due to the tension of the knot itself, making it weaker as time goes on.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 23-01-2014, 11:10
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
We have also been using the "Pre-stretch, ziptie really tight" method for years.
Unread 23-01-2014, 12:27
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Can anyone provide pictures of their zip tie surgical tubing method?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 23-01-2014, 12:34
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
I concur with the multiple ziptie method. One way we've used to prevent pull-out is to insert the largest set screw you can into each open end of the surgical tubing. You may have to work it a little bit to get it in all the way. Then when you ziptie your tubing in place, make sure at least one ziptie is across the set screw area of the tubing. The threads act as a bit of a hose barb feature to resist slippage.
Good luck to all this year!
FRC Team 3489 "Category 5"
