| Thread Tools |
Rating:
Display Modes |
#16
Re: Defence on the High Goal?
The one in the middle is only 6"...
#17
I believe(if I'm not mistaken from my 5 years of youth lax) that's the opening, which means the plastic would make it longer than 6 in.
Overally, FIRST really stunted defensive efforts compared to last year. I'm okay with that. Because this year effective defense requires much more strategy/driving/less "sit in front of FCS, block) than last year. |
#18
449 had the idea of a high blocker which was a 6 inch wide wall which would spin around one edge really fast, effecively make a 12 inch cylinder of blocking area. This entire assembly would then be placed on another rotating platform extending the range of the blocker. While it would only be 6 inches wide, it would be able to cover a much larger area.
#20
Given the restrictive parameters for teams to create devices to block the high goal, I still find it will be very effective to prevent teams from scoring.
Add the fact that there are no Safe Zones, I think many teams are underestimating the defense. Last edited by waialua359 : 23-01-2014 at 13:55. |
#22
If you are planning flimsy blocker be warned, the ball has is 2+ lbs going at some decent speed, it can cause serious damage.
#23
It's legal. The rule makes no requirement that the virtual cylinder remain fixed relative to the robot. An infinitely thin post with an infinitely thin 6" long stick rotating about a pivot on it satisfies all of the rules. The virtual cylinder will simply oscillate back and forth, with the vertical pole moving from one edge to the other and back.
#24
Well, there sort of are four of them.
#25
True, but since it does not bend, all of the ball's energy will transfer right into your frame. Will your bot tip over? With some reasonable assumptions I think you could do a nice Physics inelastic collision calculation here.
#26
#27
Yes....and we are building with that in mind.
#28
Alternatively: you could rely on your mechanism or robot structure reacting off of the player station wall to prevent your robot from tipping over.
#30
