Go to Post We know that the real goal of FIRST is not for this robot to win, but that we learn something. If i was on robotics to win, it wouldn't be nearly as fun. - Nin_estarSaerah [more]
Unread 20-01-2014, 23:15
sthreet's Avatar
sthreet sthreet is offline
AKA: scott threet
FRC #4692
sthreet is an unknown quantity at this point
[cRIO] Robot Drive... Output not updated often enough.
I got this error. According to another question on here this means that something caused the program to stop running.
No errors in code, no idea why it is happening.
The code I tested (Deleted all comments, hope it is readable.)
package edu.wpi.first.wpilibj.templates;
//import edu.wpi.first.wpilibj.Compressor;
//import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
//import edu.wpi.first.wpilibj.Solenoid;
//import edu.wpi.first.wpilibj.Talon;
//import edu.wpi.first.wpilibj.Watchdog;
public class team4692robot extends SimpleRobot
RobotDrive drive = new RobotDrive(1, 2);
Joystick left = new Joystick(1);
Joystick right = new Joystick(2);
public void autonomous()
int autotimer=0;
while(true && isAutonomous() && isEnabled())
if(autotimer<100)
drive.tankDrive(.4, -.4);
else
drive.tankDrive(0, 0);
autotimer++;
Timer.delay(.005);
* This function is called once each time the robot enters operator control.
public void operatorControl()
while(true && isOperatorControl() && isEnabled())
double leftpow=left.getY(); double rightpow=right.getY();
double powermod=.25;
if(left.getTrigger())
powermod+=.25;
if(right.getTrigger())
powermod+=.5;
leftpow*=powermod; rightpow*=powermod;
drive.tankDrive(leftpow, rightpow);
Timer.delay(.005);
public void test()
Spoiler for gif:
Unread 20-01-2014, 23:51
Re: [cRIO] Robot Drive... Output not updated often enough.
Use [ code] tags to make the code more readable.
Scroll up in the output window and see what is printed before the "Robot Drive... Output not updated often enough."
I don't see anything immediately wrong with the code. Is this the code you were running?
Unread 22-01-2014, 14:37
sthreet's Avatar
AKA: scott threet
FRC #4692
Sorry I didn't reply yesterday, internet was broken.
Spoiler for log after xyz default running messege:
[cRIO] task 0xca7f88 (worker.0) deleted: errno=0 (0) status=0 (0)
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@b entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@b entered connection state: CONNECTED_TO_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@b entered connection state: CLIENT_DISCONNECTED
[cRIO] Close: edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@b
Here is code: (deleted commented stuff.) (I'm fairly certain this is the same code that I posted, but I uncommented and recommented stuff so it may have changed. I was running this code. There is more complicated stuff commented out, but not to bad, just commented stuff out that wasn't actually connected to the digital sidecar/whatnot yet.)
        int autotimer=0;
            if(autotimer<100)
            else
            autotimer++;
            Timer.delay(.005);
                powermod+=.25;
                powermod+=.5;
            Timer.delay(.005);
    public void test()
Spoiler for gif:
Unread 22-01-2014, 16:44
AKA: Brad
#0190 ( Gompei and the Herd)
I don't see anything wrong with the code that would cause that message to be printed. RobotDrive requires the motors to be update every 0.1 seconds (expirationTime) before the robot safety code will stop them.
Make sure that the correct project is loaded in the robot.
Brad Miller
Robotics Resource Center
Unread 22-01-2014, 18:46
How many times are you seeing the message appear in the Diagnostics window? If it is constant/appearing many times it's something to worry about. If you see it happen only once or twice when the robot is transitioning between states I wouldn't worry about it.
Unread 23-01-2014, 16:19
sthreet's Avatar
AKA: scott threet
FRC #4692
Just once, but I don't know when, I can't see the window while driving it. (Don't know how to drive in developer.)
Originally Posted by BradAMiller View Post
I don't see anything wrong with the that would cause that message to be printed. RobotDrive requires the motors to be update every 0.1 seconds (expirationTime) before the robot safety code will stop them.
I am right click->running, pretty sure I am clicking on the right one.
Spoiler for gif:
Unread 23-01-2014, 16:25
Just run the driver station software.
Unread 23-01-2014, 19:14
nyaculak nyaculak is offline
FRC #0053 (Area 53)
nyaculak will become famous soon enough
This is a problem created by the wpilib's safety system(s)...Actually, you should just kill them. Call this function in the robotInit().
private void killSafety() {
    drive.setSafetyEnabled(false);
    Watchdog.getInstance().kill();
2013 MUC DC 3rd Place, FRC DC Regional, FRC Chesapeake Regional
2012 FRC DC Regional, FRC Chesapeake Regional
ERHS Robotics Club
- FRC Team 53 "Area 53"
www.erhsroboticsclub.org
Unread 23-01-2014, 21:19
sthreet's Avatar
AKA: scott threet
FRC #4692
Question Re: [cRIO] Robot Drive... Output not updated often enough.
So I added this to my code:
    public void robotInit()
Changed nothing, except the timeout messege didn't display
EDIT: We appear to be having ping problems. Robot Radio and Crio are fine. other stuff is bad. (forgot what exactly was bad, but their were two things.)
EDIT: Found this error:
Warning <Code> 44002 occurred at Ping Results: link-bad, DS radio(.4)-bad, robot radio(.1)-bad, cRIO(.2)-bad, FMS-bad Driver Station
We are attempting to switch out digital sidecars to see if that is the problem.
Spoiler for gif:
