Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 23-01-2014, 16:47
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Frame Perimeter Tolerance
If the inspection procedure is the same as last year, the inspector will be using a tailor-style measuring tape to check the frame perimeter. They will wrap it around the frame in the bumper zone across features that would define a "frame perimeter" per the rules (see the diagrams about gaps, etc). If that end tab is past the 112" mark, you're no good. So, it's up to you to decide the tolerance of the tape, but I'd say it is well under 1/16".
Regarding your powdercoat, that will be more than just a couple thousandths in thickness. I would put it into the tens of thousandths overall. So, if you gain 0.020 (0.005 per side), you're approaching the point where an inspector's tape will reflect the difference.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
