Go to Post Aww, but I ENJOY getting all up in arms about something that's ultimately inconsequential! - Cothron Theiss [more]
Unread 24-01-2014, 00:52
geek_millennium geek_millennium is offline
FRC #3567
geek_millennium is an unknown quantity at this point
Exclamation HELP! Raspberry Pi
Does anyone know how to hook up a pi to the cRIO??? And if so, how can we attach a camera with no lag and do vision tracking (through the pi)?
Unread 24-01-2014, 00:55
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: HELP! Raspberry Pi
Welcome to Chief Delphi!!!
The search function is your best friend
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 24-01-2014, 01:32
dtengineering's Avatar
AKA: Jason Brett
Because it returns results like this one: http://www.chiefdelphi.com/forums/sh...erry+pi+cri o
"Raspberry Pi cRio" is a good search term that will bring up all these threads... http://www.chiefdelphi.com/forums/se...archid=5301259
Jason
Unread 24-01-2014, 12:13
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
In case you are wondering there is no direct support in FRC LabVIEW/C++/Java for connecting your robot to a Raspberry Pi. The simplest way (depending on what language and your knowledge of them) is to communicate via GPIO. Basically when the robot gets the Auto mode packet from the DS is sets a line to TRUE or HIGH. Pi starts taking pics of the nearest reflective tape or goal lights, and when it sees white (tape) or yellow (goal lights) it sets a GPIO line to the C-Rio High telling it to shoot.
You can also use serial/I2C/SPI. Just remember the voltage level on the Pi's I/O pins is 3.3V the digital sidecar I/O runs at 5v. Also very very important! You need to let your Pi shut down as opposed to just powering of the robot and the pi at the same time One way is once the Pi gets the first signal from the C-Rio that it is in Auto have the Pi start a timer to shut down in 10-12sec if you only use it in auto or 2min 30sec if you use it in Teleop as well. And have extra SD cards with the OS and your code ready to switch out.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 24-01-2014, 18:50
yash101 yash101 is offline
AKA: null
If you are using a co-processor, you are already thinking out of the box. You will also need to think out of the box to devise a method of communicating, Pi<=>cRIO. I think you might find i2C quite easy and since it is hardwired to the cRIO, it will be high-speed, minimal lag. Also, the lag that will be present can actually by thought about before and can be compensated for in the code!
Unread 24-01-2014, 18:58
reuven reuven is offline
FRC #3211 (The Y team)
reuven will become famous soon enough
we connect the Pi to the router on the robot, and talk with it using UDP (legal under R57)
בנגב יבחן העם בישראל" דוד בן גוריון"
"In the Negev the people of israel would be tested"-David Ben Gurion
