Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 10-02-2003, 13:54
D.J. Fluck
Posts: n/a
Originally posted by Steven Carmain
Just don't put them in the microwave and cook them. We talked about this in chemistry today, and the blow up.
That reminds me of a story about one of our alumnists.... you know who you are!
Unread 11-02-2003, 10:41
foursixnine foursixnine is offline
#0469 (Las Guerrillas)
foursixnine is an unknown quantity at this point
Send a message via AIM to foursixnine
Originally posted by Solace
that was last year. the drill motors are a lot more powerful last year
Are you sure about this? I was under the impression the drills this year are much more powerful than those from previous years. Can someone confirm this?
the left and right side , i believe, are run at different gear ratios in order to achieve the same speed. (true, one side is probably a little more powerful than the other, but i don't think that that affected anything much.
In theory having more torque on one side of your drive would hinder straight line acceleration since one side would be accelerating faster than the other provided there wasn't any wheel spin. In other words the robot would have a tendency to turn in one direction when accelerating. I suppose this could be corrected w/ programming but you would be putting yourself at a disadvantage since you would be giving up the power of your stronger motors to match the power of the weaker set.
Unread 11-02-2003, 10:54
Jay5780 Jay5780 is offline
no team (Aztechs)
Jay5780 will become famous soon enoughJay5780 will become famous soon enough
I thought that Woodie spacifically stated that gerbil power was not allowed this year....
Great Bot guys
Jay
Unread 13-02-2003, 16:09
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
So the robot would want to turn in an arc. That would be terrible in a game like this, huh?
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 13-02-2003, 19:04
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Well if you want to use dead reckoning for the autonomous period its really really bad. It basically limits any ability of yours to determine where it is going to be.
Team Website
Unread 13-02-2003, 20:08
I highly doubt the arc you would get is what's desired during autonomous, and even if it was when you think about all the variables involved the drive would still be at a disadvantage. Never the less it is an interesting way of taking the arc. Theoretically you could tune the speed of your robot to take the correct path, you wouldn't be the fastest but the system would require virtually no programming skill whatsoever.
Unread 13-02-2003, 23:01
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Our drivetrain is similar to last year, and while I can't say it goes in a perfect straight line, I can say it doesn't go into an arc. Truly you only notice it if the robot is going down the whole field, you notice that pitched a little to the left. Our auto programs are also good, and they actually use right angles to find its desired path. It's a really good drivetrain system, and served us well last year.
Unread 13-02-2003, 23:13
I just want to make it clear I'm not trying to put down the drive system it looks to be one of the better systems I've seen. It actually isn't all that far from our own system this year. The differneces in acceleration and power I mentioned are so minimal chances are you won't notice it on the field and it wont have any bearing on the overall performance of the bot.
Unread 26-02-2003, 16:07
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
How well are you guys at turning? We used the same wheels and we have four wheel drive, using a drill and cim on each side, but when we turn it doesn't want, well it will, it just jumps a lot and beats up our bot. I was wondering if you might have had any trouble andfigured out something or if it is just us. We would appreciate any help we can get. Anybody?
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 26-02-2003, 16:27
KevK's Avatar
KevK KevK is offline
#0121 (Islanders)
KevK is an unknown quantity at this point
As driver of our robot, the drive train works great, with 6 wheels instead of just 4 like last year, it grips the carpet a little more, causing it to bounce a little bit, but it all depends on how it's driven. If I take it easy when turning it's fine. I don't think i'm going to have to do a lot of quick manuvering, so we should be all set. Also the carpet we tested on was hardly secured and bunched up, it should be better at competitions. All i can say is that you should take it easy when your driving.
121 used to stack, unstacks, and gently removes robots from the ramp!!
Unread 26-02-2003, 17:11
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Matching up torque-speed curves can be tricky, but it's beneficial if you get it right.
The new drill motors put out 193 oz-in of torqe at 1,100 RPM at their maximum efficiency (65% drawing 21A).
The CIM motors put out about 64 oz-in of torque at ~4400 RPM at their max efficiency (76% drawing 23A).
When adding a typical 10% inefficiency for gearing the CIM motor, you can see that the motors are rather close.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 26-02-2003, 21:23
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Six wheel drive
Do you do anything special to make your robot turn? Normally all those wheels on the ground would make turning difficult. We found that our Bosch got really hot (while the chip's were relatively cool) we solved that problem by cutting the power to the bosch in half, now both the bosch and the chip's get equally hot under strenuous circumstances.
We have a six wheel design (have for every year), and offset the center wheels by 1/4" so the robot is actually balancing on the center wheels: makes for easy, friction free turning. GOtta use the Gyro for stabilization, however, because it turns TOO easy!
Photos at http://www.barello.net/FIRST/Images
Unread 26-02-2003, 22:02
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
we have a strong 4 wheel drive system that would jump during turns on the carpet. We fixed this easily by adding two caster wheels on the back that are threaded on 3/4" bore 2" stroke pneumatic actuators. when we are on the carpet they are down for easy turning and when we are on the ramp they are up for traction and pushing power. All at the click of a button.
Unread 26-02-2003, 22:38
shawny963 shawny963 is offline
shawny963 is on a distinguished road
Send a message via AIM to shawny963
our robot has 6 wheel drive on drill 2 motors, we had to smooth the wheels though. There was a ridge in the center that prevent sideways movement of the wheels on carpet. As you might expect the drill motors kept on overheating. We smoothed this ridge of, so we now only have grooves that provide traction in a forward or reverse direction. We CAN turn very well and have a lot of control on the HDPE. So far we have been able to push robots on the mesh while we are on HDPE. Check out our bot by doing a search for " image 930 " on chief delphi. Look at the thread, there is two pics.
Image Discuss: TechnoKat Teaser #3 CD47-Bot Robot Showcase 14 07-04-2003 01:09
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Image Discuss: STUDENTS working on 121 CD47-Bot Robot Showcase 5 19-02-2003 22:46
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
Triple Crown Belongs to 121! Rick Off-Season Events 58 16-06-2002 22:47
