Go to Post Your students are my idols. - Al Skierkiewicz [more]
Unread 07-02-2003, 20:14
O AntiGravity O O AntiGravity O is offline
O AntiGravity O is an unknown quantity at this point
40 amps a must?
Sorry its our team's first time posting, but we've been keeping up on all thats been going on here. Anyway, we're dangerously overweight and looking to shed any pounds in any way possible. So do we have to use the board with the 40 amp fuses for the drill motors, or could we just stick with the 30 amps which have been running fine for us?
Unread 07-02-2003, 20:18
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
You are allowed to use the 30 amp fuse for drill motors but I wouldn't recomend it. The drill motors work there best at 60 amps and tend to blow breakers. I don't think you will be saving that much wait by removing the 40 amp panel anyway.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 07-02-2003, 20:32
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
40A a MUST
Page 10 of the robot rules says 40A used with drill motor and CIM, so if you want to use ethier you must use the 40A block.
Unread 07-02-2003, 20:37
rust710's Avatar
Opps, I missed that. But it sounds weird to me that FIRST will get mad over a breaker too small.
Andrew Radamis
Programmer on 862
Unread 08-02-2003, 16:45
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
If, as your question suggests, you are looking to save weight by using a 30A breaker rather than a 40A, it would be safer to just drill an extra 1/4" hole in something. That would amount to the same weight loss.
Don't assume that a 30 amp breaker weighs 3/4 of a 40 amp one.
Unread 08-02-2003, 16:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
These drill motors are more powerful, meaning they draw more current, so a 40 amp breakers are for your benefit. You will not experience as many problems tripping breakers, etc.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 08-02-2003, 17:02
oneeightytwo oneeightytwo is offline
#0011 (M.O.R.T.)
oneeightytwo is an unknown quantity at this point
I agree
Our robot has been moving around on the 30 amps and we have popped a breaker or two and we switched to 40 and had no problems!
There is no impossible.
Impossible has been rewritten
Impossible is now possible.
You Gotta Believe
GO M.O.E. (NOT!!!!!!)
GO M.O.R.T.
Unread 08-02-2003, 23:01
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
we're moving on the cims and we keep popping the 40s at low speeds
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 09-02-2003, 10:07
TNT280Staff's Avatar
TNT280Staff TNT280Staff is offline
AKA: Joe Horth
None #0280 ("TnT")
TNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the rough
400 1/4" drilled holes in aluminium = 1 lb of dieting
Unread 09-02-2003, 13:35
John Bono's Avatar
John Bono John Bono is offline
#0990 (We don't have one :cries:)
John Bono is an unknown quantity at this point
Well see, there's your problem--you're only drilling 400 holes. I kid, I kid--and that's how thick of aluminum? We also have some steel, too.
"Proof is King. Logic is Prime Minister." -Force-Attuned Krokoth
"Any fool can make things bigger, more complex, and more violent. It takes a touch of genius--and a lot of courage--to move in the opposite direction." -Albert Einstein
"Never put off until tomorrow what you can do the day after tomorrow." -Samuel Clemens
Unread 09-02-2003, 15:28
AKA: Joe Horth
None #0280 ("TnT")
Not sure on the thickness... it was actually something Woody Flowers said 3 or 4 years ago at Kick off in New Hampshire
Unread 09-02-2003, 16:28
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
1/8" AL 1/2" holes = 300 holes per pound
and yes you may use any breaker you want on the drill motors, however i think you still must use the larger breaker panel, If you are that close on weight you may want to look at some other area in which to reduce weight.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 10-02-2003, 18:24
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Go with TNT2 and drill speed hole!
Unread 12-02-2003, 17:28
John Bono's Avatar
Speed holes, eh?
Unread 13-02-2003, 19:04
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yah, speed holes, you can always use swords to make them
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
6 awg wire how much amps? viper Electrical 3 20-01-2003 14:29
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
What else do we want? archiver 2000 63 23-06-2002 23:19
60 amp Circuit Breaker Info archiver 2001 1 23-06-2002 22:33
