Go to Post If people really want to see "better" refereeing, they should see what they can do to help FIRST make better. - petek [more]
Unread 24-01-2014, 09:40
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Moving a motor at specified power
Originally Posted by otherguy View Post
When the motor is run at full voltage (1.0 or -1.0) for the duration required, it doesn't have enough time to accelerate?
If that is the case, then you need to address your problem with a mechanical solution (gearing?) to provide the acceleration desired given your motor's spec.s and the load it is driving.
Agreed. If your system can not provide enough peak power, any closed loop system will simply stay at that peak and still be limited by the battery. A servo does not create power that is not there, it controls the application of the power. Re-evaluate your motors and/or gearing.
