Go to Post Check Chief Delphi, and if there isn't a post, make one. - sithmonkey13 [more]
Unread 24-01-2014, 15:47
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
TImed Sequence help
I am testing a timed sequence for our ball launcher, but it appears my code isn't working. Every time we press the button, motor clicks on for just a split second, then turns back off. Could someone review my code and tell me where I messed up?
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 24-01-2014, 15:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: TImed Sequence help
What does the false part of the statement look like? If you hold the button down does the timed sequence complete?
Unread 24-01-2014, 15:53
katsauga's Avatar
Lead Programmer
I have not created a false statement yet. And no, it does not complete the timed sequence
Unread 24-01-2014, 15:55
Flywheel Police
I haven't done any labview programming for a few years, but why not just take the output directly from the button into the case block?
Unread 24-01-2014, 16:03
katsauga's Avatar
Lead Programmer
It now completes the timed sequence, but, the timing is all off.
Unread 24-01-2014, 16:08
How is Motor1 being created? If it has the motor safety enabled, it will act as you describe because you're only setting it once. The motor safety will shut off a motor if it doesn't get an explicit command at least every 100 milliseconds.
Are you seeing any errors reported in the Driver Station diagnostics window?
Unread 24-01-2014, 16:09
Is motor safety enabled for motor1?
katsauga's Avatar
Lead Programmer
So I should turn the MotorSafety off?
Also make sure you're not trying to control Motor 1 in your Teleop code.
Unread 24-01-2014, 16:12
katsauga's Avatar
Lead Programmer
It was the Motor safety, thanks! I did't realize that is what it did! Thank you for your help!
Unread 24-01-2014, 16:13
No, you should answer the question first. Show us the part of Begin.vi where you open Motor1. Then we can ask more questions to lead you to the most appropriate solution.
And RufflesRidge has a good point. Do you control Motor1 anywhere else in your program?
Unread 24-01-2014, 16:19
katsauga's Avatar
Lead Programmer
I have already removed it from the teleop.vi , before this. I suspected that might have been an issue. It is working now though. So you would like me to post a screen shot?
Unread 25-01-2014, 23:23
If it's working, you probably don't need help getting it working. Unless you have more questions about something, there's no need to post your code now.
Unread 26-01-2014, 13:42
katsauga's Avatar
Lead Programmer
Talking Re: TImed Sequence help
Alright, Thank you for your help
