Go to Post If they're going to blame you for it anyway, you might as well have fun. - Rick TYler [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 24-01-2014, 16:05
Brennen3828 Brennen3828 is offline
Scout Leader/Computer Aid Designer
FRC #3160 (FROG: FIRST Robotics of Grove (Oklahoma))
Team Role: Scout
Brennen3828 is an unknown quantity at this point
Scouting Sheet
I was thinking instead of using pencil and paper to record all the data, why can't we use Google Forms.With Google Forms, all of our scouts can enter data through it quickly and efficiently. And the best part about Google Forms that all responses will go to one spreadsheet all organized immediately!
I made a scouting sheet for my team this year through Google Forms. Please reply on what you think about it, what needs to be added, or what needed to be removed.
I copied the Form to Microsoft Word to avoid anyone submitting the form.
Brennen
Team 3160
Unread 24-01-2014, 16:44
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Re: Scouting Sheet
How will you get to the internet in the venues for the upload of data?
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 24-01-2014, 16:52
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Re: Scouting Sheet
That is normally the holdup of most teams at events. If you plan to use any internet based system, make sure to plan to set up a hotspot for your team.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 24-01-2014, 17:08
Jhultink Jhultink is offline
AKA: Jaredt Hultink
FRC #2771 (Code Red Robotics)
Jhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the rough
Re: Scouting Sheet
I know at least in Michigan you can't do this. They have people walk around to find the hotspots and ask you turn it off. I heard once your team could potentially be kicked out for it, though I am not sure how accurate that is.
Unread 24-01-2014, 17:32
Troger's Avatar
Troger Troger is offline
AKA: Eli Bliss
FRC #3131 (Gladstone Robotics)
Troger is an unknown quantity at this point
Re: Scouting Sheet
It wouldn't have to be online. If you used one tablet or iPad to utilize the form, it would still organize and store all the information on the machine itself. However you have to deal with it being less efficient because its on a machine-to-machine basis.
The cloud is nice but sometimes you have to accept that its not available and revert back to other means.
Eli Bliss
Gladstone Robotics | FRC Team 3131
Unread 24-01-2014, 22:10
Team Role: Scout
Re: Scouting Sheet
Thank you for all the responses! Is there another way for scouting efficiently other than pen and paper?
Unread 24-01-2014, 22:55
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Scouting Sheet
Many teams have developed scouting apps for mobile devices. Another approach I've seen is using a local web server with computers connected via Ethernet cables. If you set the post age in further back in the display options of the Scouting sub-forum, you can find some related threads from last season: http://www.chiefdelphi.com/forums/fo...&daysprune=365
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 25-01-2014, 00:42
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Re: Scouting Sheet
The one way you could make your way work for you is to use them locally then during down times (breaks for lunch, etc) have them taken out to the team trailer where you can power up a hotspot away from the arena. Mobile hotspots usually have a very small radius.
Michigan though does have people wander around checking. We developed an app last year that saved the data to the ipad then when we got back to the hotel we synced them all together to our cloud. While it worked great, this year we are doing it a bit different. Either syncing via wifi to a laptop server or via bluetooth. That way we can turn on an ad hoc quick network for 30 seconds or so, do the sync then switch it off. Plan to take the laptop out into the lobby or parking lot if we have to.
Unread 25-01-2014, 01:42
Aetas's Avatar
Aetas Aetas is offline
Deranged Pikachu
AKA: Anita
FRC #1775 (Tigerbytes)
Aetas is an unknown quantity at this point
Re: Scouting Sheet
I agree with the others in regard to the problem of attaining internet access. It may be efficient to have a scouting binder, at least, and then eventually add the information online at the nearest time possible, and then email copies to the team perhaps. Our team has found that a scouting binder is the way to go when it's in paper and pencil though, since it's easier to carry around; online is nicer in case something is lost though.
The actual scouting sheet looks good. We tend to have numbers on our sheet too- that is to say, how many times a team scores and how accurate a team is in regard to said scoring. We also have an extra details category for pit scouting, where we ask about driving experience (how long have the drivers been driving, how much they practise, if the drivers are veteran or not, etc).
Also, maybe add a diagram? We try to add a diagram of the field so that it is visually pleasing and more comprehendible to our newer scouts and clears up confusion with the directions and all that- usually the diagram is colour coded as well, to add just a little more clarity.
As well as this, maybe add the team name in addition to the team number? Sometimes, it's easier to recognise names as opposed to numbers, and as such, is good for quick reference.
Unread 25-01-2014, 13:38
shelldonboyd shelldonboyd is offline
FRC #1622
shelldonboyd is an unknown quantity at this point
Re: Scouting Sheet
Like the others who posted before me you would have to set up a hotspot for your team if you are using any of the new technology we have. But also your sheet is really long hope you got it simplified or it might confuse people. Your team size is also depended
Unread 25-01-2014, 17:03
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Scouting Sheet
You can't set up your own hotspot, if the FTA(s) will find it and tell you to turn it off. We use paper and it works great.
Unread 25-01-2014, 19:11
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: Scouting Sheet
5.5.1.4
Teams may not set up their own 802.11a/b/g/n/ac (2.4GHz or 5GHz) wireless communication (e.g. access points or
ad-hoc networks) in the venue.]
Mentor http://www.teamtitanium.org/
Unread 28-01-2014, 16:19
RoboticWombat's Avatar
RoboticWombat RoboticWombat is offline
Doctor Robotic Wombat Is In!
AKA: Luke Baker
FRC #4342 (Demon Robotics)
Team Role: Tactician
RoboticWombat is an unknown quantity at this point
Re: Scouting Sheet
The TeleOP Score Cycles jump from cycle 4 to 6 and skip 5. Don't know if you wanna change that or not.
Unread 28-01-2014, 17:02
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Re: Scouting Sheet
Originally Posted by Jaxom View Post
5.5.1.4
Additionally, section 4.15 of the Administrative Manual:
Originally Posted by The Manual
4.15 SITE RESTRICTIONS
  • Do not arrange for Internet access or phone lines on the site or attempt to connect to the Internet.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 28-01-2014, 17:30
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Scouting Sheet
But Bluetooth doesn't violate these rules, correct?
[IMG] code is Off
