Go to Post the programmers are -- um, well, doing what programmers do: drinking more Mt Dew. - Roger [more]
Unread 23-01-2014, 19:32
DDSLoan96's Avatar
DDSLoan96 DDSLoan96 is offline
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
DDSLoan96 is an unknown quantity at this point
Talons flash red on enable
Today we were planning on having the robot running around but we have hit a bit of a snag. When we enable our robot all of our Talons flash Red which means there is a fault. The only thing we see in the Talon manual is that it could be either low input voltage(checked we get 12 volts at each), over temperature(Cold to the touch) or a shorted output transistor. What can I do to fix this
Unread 23-01-2014, 21:10
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Talons flash red on enable
Are you sure its a fault? They also flash red for reverse, which may happen if they aren't calibrated and/or you are leaning on a control.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 23-01-2014, 21:54
raptaconehs raptaconehs is offline
FRC #3200
raptaconehs will become famous soon enoughraptaconehs will become famous soon enough
It just means that the Talons haven't been configured yet. Once you configure them you will see that they will go to a solid orange state on enable.
Unread 23-01-2014, 22:57
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Here is the Talon user manual. It contains the fault codes, and how to calibrate the controllers.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 24-01-2014, 09:12
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Does this have to be done with no motors attached
Unread 24-01-2014, 09:15
Chris_Ely's Avatar
AKA: luckof13
It doesn't matter if the motors are attached. But the motors will spin when calibrating.
Unread 24-01-2014, 10:01
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
The motors don't usually spin for us when we are calibrating.
Unread 24-01-2014, 10:18
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Tried calibrating them this morning but haven't had any success. I'm going to probably set them up on a testbench when we meet later today and see what we can do then.
Unread 24-01-2014, 10:35
Flywheel Police
When the robot is enabled, do the wheels have resistance like they are getting power? I'm wondering if the motors are being told to move at a very low speed. What is the code telling the motors to do?
Unread 24-01-2014, 13:09
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Its not a code issue at the moment since the output is disabled on the talons because it is detecting some sort of fault. Our electrical/programming mentor is coming today to help me figure this out
Unread 24-01-2014, 14:15
Chris_Ely's Avatar
AKA: luckof13
The LED on the Talon flashes between red and orange when a fault is detected. If the LED is just flashing red like you said earlier, then the Talon is outputting reverse.
Unread 24-01-2014, 18:46
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Talons won't accept any sort of calibration. Joysticks are working because they work on our old robot and when we hook up a jaguar it works. Any suggestions?
Unread 24-01-2014, 19:22
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
And now they are magically working. Not sure what we did but they work now
