Originally Posted by BJT
It doesn't fall apart easily on its own, but its pretty easy to pull off with fingers. just not real confidence inspiring. I don't have access to it till tomorrow.
I noticed it when I was swapping the bearings for the 2 gears, they were switched, round-hex.
If you can easily pull it with fingers, it'll fall out in no time on a vibrating and shaking FRC robot. If you have the right size bearing, the hole is probably oversized a bit, which is bad for me, because I'm counting on it being a press fit for our winch thing, and if it's not, I don't have time to wait for another gear to get here...
I'm assuming you have the other dog gear for the transmission (and another set for a second gearbox?). When you get access to the gears, could you see if they're all like that?
