Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 24-01-2014, 21:52
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: How to Program Limit Switches
Hello, welcome to FIRST!
So just making sure, you're just asking about the logic? I program in C++ so I'm not sure about any of the specifics, but I'd imagine something like this would be a good start point, then add on more and more to it until you like it:
WindowMotor.Set(1.0);
while(LimitSwitch1.Get() == false)
WindowMotor.Set(-1.0);
while(LimitSwitch2.Get() == false)
WindowMotor.Set(0.0);
Now, a couple things you may want to look at is decreasing the speed, so that you don't break the limit switch or having maybe a time for it to slow down so that you don't burn out the motors by immediately flipping it in reverse.
This is just the template logic, so try and mix it up and make it your own!
"Measure with a micrometer, mark with chalk, cut with an axe."
