Go to Post The pen [may be] mightier than the sword, but the bandsaw can chop them both. - Marc P. [more]
Unread 24-01-2014, 22:34
Happy Birthday! Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
While loop not working in autonomous
Hi all,
I have created a while loop in autonomous that uses a boolean from the vision processing (hot goal). I have a System.out that will print repeatedly in NetConsole, but my relay will only go forward the first time. Relevant code below:
        while(h){
            relay.set(Relay.Value.kForward);
            System.out.println("Firing");
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 24-01-2014, 22:49
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: While loop not working in autonomous
Could you provide some more context to your issue? Are you using the SimpleRobot or IterativeRobot base class? It would help to see the class this code is located in, or at least more of the surrounding code.
I'm not entirely sure what the issue is here. You set the relay to the forward value, and it will stay there until you set a new value for the relay. What is the desired behavior you are looking for?
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 25-01-2014, 00:19
FF: Bobo Brigade
AKA: Zachary H.
Sorry for not giving enough information. We are using SimpleRobot. It is located within public void autonomous(). I have the while(isAutonomous() && isEnabled()) loop commented out, so as not to kill the flash on the cRIO. I can post the whole code tomorrow morning, but this is the only code that acts on the relay. To clarify the problem, when I run the program, it prints "Firing" repeatedly in NetConsole, but the relay only turns on for the first time through the while(h) loop. Also, the green LED on the digital sidecar turns on and off with the motor. The h Boolean is set based on whether or not the goal is hot, and I have confirmed this to work.
Zaque (Zach) H.
President
Unread 25-01-2014, 07:21
Originally Posted by Zaque View Post
To clarify the problem, when I run the program, it prints "Firing" repeatedly in NetConsole, but the relay only turns on for the first time...
So you're saying the relay turns on for the first loop, and then it turns off and won't come back on? If you're trying to fire the ball, I'm assuming you want the motor to stay on for the duration of the loop?
From the code snippet you posted, I see no reason for the relay to turn off. You should check the rest of your code to make sure nothing else is trying to control the relay.
