Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-01-2014, 14:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: 5" wheels
Try skyway wheels. (Remember them?) They used to be in the KoP and they sell a 5inch wheel.
http://www.skywaywheels.com/products_004.htm
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-01-2014, 14:49
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Unlike many here...
I highly recommend banebots wheels for drivetrains.
They come in 4 7/8 diameters. They have crazy high traction. They do wear more quickly because of this though, so it is usually wise to get a spare set of you go this route. Get some blue wheels for testing, orange or blue for competition.
Unread 24-01-2014, 15:13
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: 5" wheels
Ahh, the infamous Skyway wheels.
Great find!
Unread 24-01-2014, 16:06
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: 5" wheels
If you do opt to go with Banebots wheels for the drive, I'd suggest going with one set of 3.875" wheels to be used on one end rather than a 4.875" to be used as the center wheel. You'll still end up with only four wheels in full contact with the carpet under normal conditions (a "pivot" as you called it), thus achieving the shortened wheelbase and improved turning. However, you'll have a much less significant difference in surface speed of the wheels (a larger diameter wheel spinning at the same rate as a smaller diameter wheel will have a faster linear velocity at the edge of the wheel). Especially if you mount the banebots wheels on the lighter end of the robot, so under nominal conditions they won't be contacting the floor (thus your four wheels with identical diamters will be in contact). You want to avoid differening surface speeds when possible, so you can harness the static friction of your treads rather than the lower dynamic friction.
Unread 24-01-2014, 23:13
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: 5" wheels
Originally Posted by Gregor View Post
Raise one of the outside wheels 1/8". Drill a clearance hole in the current existing holes for your outside wheels, then rivet or bolt a new piece of metal overtop, which the axle hole raised.
I know 610 did this last year, ask them for a few pictures.
Similar to this^
Drill the hold 1/8" higher. Insert "shims" under axle. The shims we have used were steel sheet metal.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 25-01-2014, 08:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: 5" wheels
If you have bolts as axles, (not live axles) you could re-drill the 3/8" holes with 1/2"(offset higher 1/8") and change wheel bearings to 1/2".
Or check a few 4" wheel brands, like the vex or Andymark traction and see if they are slightly bigger or smaller.
Unread 31-01-2014, 21:17
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Thanks for the help everybody. We got it working by using aluminum plates riveted to the chassis as Gregor suggested. It works like a charm now
