Go to Post Those teams with too much pride will hinder their alliance. Know your strengths and weaknesses and be honest about them. - Andy Brockway [more]
Unread 24-01-2014, 21:10
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
How to Program a Servo
Hello - Im the head programmer/electronics guy at LF Robotics. I am the only one of my kind on the team and this is my first year so I have absolutely NO experience so PLEASE bear with me.
I want to have a servo that by the touch of say button four on the joystick will rotate 45 degrees to the right and once it reaches that point will return to its original position.
I am using Command Based Java in Netbeans.
I know how to do simple things with it - like I said this is my first year.
ANY help will be GREATLY appreciated - THANKS!
Unread 24-01-2014, 21:53
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: How to Program a Servo
Hello again! I would recommend asking all your questions in one thread please. It makes the life of people who are trying to help you much easier xD
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 25-01-2014, 00:38
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
If you can use robot builder to create your subsystem and commands. Robot builder is create for beginners. Always make sure to review the code it generates and try to understand what it is doing.
The basic approach (no code. I'm a C++ guru and am not confident I would not provide broken java code.).
Create a subsystem and add a Servo to it or add a Servo object to an appropriate existing subsystem.
Solution A
Create a command that moves the servo to position 1.
Create a command that moves the servo to position 2.
Create a command group that adds sequentially:
--MoveServoToPos1Command
--WaitCommand(timeItTakesForServoToRotate45Deg)
--MoveServoToPos2Command
Assign command group to a joystick button.
Solution B
Create a command that moves the servo to position 1 and then waits the timeItTakesForServoToRotate45Deg and then moves the servo to position 2.
The choice is up to you how much you want to break the problem down. 1 command will work but a command group of discrete commands would be more flexible.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 25-01-2014, 14:05
LFRobotics's Avatar
FRC #4623
Okay - THANKS - I think I got it figured out now.
