Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 21-01-2014, 15:18
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Re: FRC 2530 Inconceivable Pneumatic Shooter
Originally Posted by cjsager View Post
Its really awesome to see that we are not the only team trying this kind of a shooting mechanism.
Our shooter was actually inspired by our 2010 robot's original kicker, which was a two stage beast. We did end up doing some research during our brainstorming, and we were in fact encouraged ourselves by the success of 95's 2008 design. Ours is currently 3 stages, and we are waiting on a few more cylinders to arrive in order to finalize it. I hope to see you guys continue to find success with yours as the build season progresses.
Thanks CJ! You too!
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 21-01-2014, 16:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Unread 21-01-2014, 16:28
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by blazeflipper View Post
... Also accuracy, if you only have one small point of contact it might not be as accurate as you want. Just like playing pool, it works most of the time but the one time you miss is when you need it the most. ...
Can't wait to see the size of the chalk block for the end of this "cue" stick. Or the applicator mechanism that twirls it onto the tennis ball between shots.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 21-01-2014, 21:41
AKA: Vince Wagner
All in due time me boy, all in due time.
It's Inconceivable!
Unread 24-01-2014, 18:11
4561Terrorbytes 4561Terrorbytes is offline
FRC #4561
4561Terrorbytes is an unknown quantity at this point
Hey, this is Myles from team 4561. How did you exactly get your pneumatic to work? We tried a similar pneumatic design and it worked "terrifically". We had 3 pistons connected to one solenoid. We weren't losing pressure, but the pistons shot out lower than usual.
Unread 25-01-2014, 06:47
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The most significant choke point in almost every (properly implemented) pneumatics system is the solenoid valve. You should be using 3 solenoid valves, one per piston, to achieve the fastest deployment time possible. There are also numerous threads in the pneumatics section detailing other techniques to maximize deployment speed/power if using 3 valves doesn't do the trick for you.
Good luck!
Unread 25-01-2014, 10:06
AKA: Vince Wagner
Hi Myles,
James CH95 is correct. One solenoid per cylinder. Also, shorten the tubing as much as possible. You would be amazed at the difference cutting 6 inches of tubing out can make. Also, avoid the 90 degree elbow fittings whenever possible.
Good luck!
It's Inconceivable!
